I originally posted on allfordmustang.com and haven't really gotten much help so I thought I'd post here to see if anyone had any ideas or could help.
Original post on AFM
I hope some one can help me with diagnosing an overcharging problem on a friends 72 Mach 1. The car is complete with a fresh 351, the new charging system consists of all new regulator, battery, and a 3 post alternator setup for a serpentine belt. The first issue was a non-charging one, w/ no alternator dummy light illuminated. The battery and regulator were replaced and a new problem presented itself. When the car is cranked the alternator dummy light comes on and the voltmeter slowly climbs to 16+ volts. Checked it with a secondary handheld voltmeter and sure enough 16 volts. Checked the wiring against a schematic and from what can be seen, all appears to be correct. By searching through other threads I read that the only way to get 16 volts on the voltmeter would be a bad regulator, replaced the regulator again and the problem is still present. This is driving us nuts. My next step is to pull the wiring harness apart and start over. Any ideas as to what specific wire either being shorted or spliced could create this problem? Also, whats the square harness plug (approx .5"x.5") with the fuseable link tab on it for?
#1 Most common reason is faulty or missing ground strap from engine block to body.
My reply:
The ground strap is good. I don't believe its a ground issue. I'm leaning more towards something being wired into the harness somewhere causing an improper load, but I'm not sure what exactly would create the issue I've got. I did find the radio hum capacitor wired straight from the neg terminal on the battery to the fender to ground it, rather than from the "A" terminal on the battery.
My new problem:
ok this is really starting to drive me nuts. HELP. I took the alternator off and had it bench tested, it checked ok and reinstalled it on the car. I installed a new wiring harness and a new voltage regulator. and heres what happened.
Start the car and it shows between 12.3-12.7v across the battery. If I turn the lights on it shows around 12.1 volts. There is no change in voltage with rpm speed, and if I cut the lights off the voltage returns to between 12.3-12.7v. I also now have the alternator indicator on my dash on. It seems to be charging but seems a little low to me, and whats the deal with the indicator lamp? Could it be wired backwards?
My reply:
My new problem:
