Overdrive in 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2007, 02:45 PM
Overdrive in 700r4
I recently installed a rebuilt 700r4 in my PU. I've adjusted the TV cable and the shifts are at the correct speeds. My question is about the shift into overdrive. When it shifts into overdrive, it seems to shudder and lurch. If I manually downshift to 3rd, it is smooth again. It only does it in overdrive. Any ideas?
Old 08-04-2007, 03:53 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Is the trans setup for lockup of the converter in over drive only?
Is the trans a hydraulic lockup for the converter?
Is it setup for electric lockup ?
If it is an electrical lockup , have you tried it with the electric unplugged?
Does this lurch continue at all speeds?
Does the shift to OD seem early (low speed) causing the engine to mis-fire?
Does it feel like the converter clutch is applied as it shifts to OD?
Old 08-04-2007, 07:59 PM
It is setup for lockup that is electric but triggered off of a pressure switch from the external port on the right side of the transmission. It is very smooth until the shift into overdrive. I have not tried it with the system unplugged. It does seem to shift into overdrive early (about 45 mph). I can't tell if the converter clutch is engaged when it shifts. This is my first 700r4. Previous transmission after the standard was a TH400. Thanks for the response.
After market overdrive or 700r4 Jared Engine 7 12-08-2008 01:19 AM
700R4 or TH400 w/ overdrive 53LEDSLED Transmission - Rearend 8 05-28-2007 08:22 AM
700r4 vs. th350 with VOD overdrive steemin Transmission - Rearend 12 01-09-2006 12:25 PM
700r4 no overdrive wwhijr Transmission - Rearend 4 06-07-2005 04:52 PM
700R4 won't hang in overdrive slingslingbinks Transmission - Rearend 8 03-29-2004 09:43 PM
