Overdrive take off clunk slip I guess - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2012, 02:10 PM
1993 4x4 Chevy suburban will move in 1st 2nd and 3rd but will not go in overdrive 1st clunk and slip problem I can put in overdrive once Its past 2nd so what's going on there one more time if it's in overdrive where it should be will not move but if I pull the shifter down to any other gear it will go this is on a automatic 4l60
Old 04-30-2012, 12:36 AM
Bent, mis adjusted linkage??
slip yoke doesn't (slip) on... markzepp820 Transmission - Rearend 14 04-29-2008 01:29 AM
79 TA, clunk, clunk, clunk sounds under hard steering Gladis Suspension - Brakes - Steering 13 05-01-2007 07:34 AM
clunk mlaudon Hotrodding Basics 2 03-19-2006 02:53 AM
Rearend clunk briz Transmission - Rearend 8 09-11-2005 07:14 PM
anti slip or no slip Terry411 Transmission - Rearend 2 05-01-2003 04:05 AM
