Which overdrive transmission? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2006, 04:48 PM
Choctaw Bob's Avatar
I have a 23 T with a 69 396 BBC and a TH350. I would like to install an overdrive/lockup converter trans that will stay together in front of 500 HP in a 1800 pound car on rgw street. What would be the easy and cheap way to do this?
Old 04-03-2006, 06:50 PM
700R4.
Handles the power easily with no special parts required, has great adaptablity in the converter area, and is relatively inexpensive. Good trans shops should be able to help you with various scenarios regarding shift quality and converter needs, cable, etc. Figure $800-$1500, depending upon your desires.
Old 04-03-2006, 07:06 PM
I put a 700R4 in my 55 Belair last year and just love it. The only problem is with all the quiet in the car my wife wants to talk to me on trips now. Maybe I need a good sound system???
Old 04-03-2006, 07:18 PM
I don't have that problem with the engine noise, header hoise and wind noise. The car is better than music.
Will a 700R4 bolt up to my engine? What about a converter? Will the converter from a late model bolt up? How about length?
Old 04-03-2006, 07:20 PM
Check for PM....
Old 04-03-2006, 07:30 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
I have a 23T bucket with a 383 stroker in it. I have the 700r4 trans and love it. You can get a stock converter that will stall at about 2300, but locks up. It will all bolt to your big block.
Old 04-03-2006, 08:51 PM
Great. What year and model converter should I look for? Sorry about the ignorance. The last Chevy I built was a 67 SS 396 Camero in 1973. I vaguely remember that Chevys were all the same bell housing. Mine is internal balanced.
Old 04-03-2006, 09:29 PM
The 700r4 is a good choice. Have one in my 70 Chevelle ( its a 1987 ). I have a B&M Hole shot 2000 converter and the whole thing seems to work pretty well. I even raced the car for a couple of years with no problems. When installing it I think you have to add a converter lockup switch. B&M should be able to supply that. Good luck on the project.
Joe
Old 04-03-2006, 09:49 PM
Joe
Thanks Joe. I think I will get my neighbor (he owns a trans shop) to start looking for a core we can build. Then a Kit from Performance Auto. should do the trick.
Old 04-03-2006, 11:18 PM
Jmark's Avatar
Make sure your neighbor chooses a later model 700 with the aux. valve body. It will have a lot of the better upgraded parts compared to the earlier 700's.
Mark
Old 04-03-2006, 11:26 PM
Mark
What year should we look for?
Old 04-04-2006, 06:28 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
General acceptance of the "better" transmissions are the 1988 and later model years. (1988-1992)
Old 04-04-2006, 06:58 AM
Thanks! I'll put the information to use
Old 04-04-2006, 10:37 AM
transmandan's Avatar
Automatic Trans Specialist
What overdrive trans to use
I build 700R4 Transmissions that will hold up with no problem to you application. I have them in alot of street rods and even a 550HP turbo charged silverodo The main thing is get a good converter. If I can help let me know.
Old 04-04-2006, 03:21 PM
I would like a lockup converter. Do you recommend any particular brand?
Transmission Want Shift Into Overdrive butchs18 Transmission - Rearend 4 06-08-2005 05:02 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
351C - overdrive transmission Steve_M Transmission - Rearend 7 09-16-2003 05:50 AM
94 olds 88 transmission - overdrive litt810 Transmission - Rearend 3 08-09-2003 03:20 PM
Overdrive transmission merkery Transmission - Rearend 1 06-25-2002 09:25 PM
