overdriveconversion 80 chevy p/u - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2006, 12:08 PM
need info on insallation pertaining to driveshaft length .tvs cable. trans coolerlines shifter linkage fluid level dipstick & tube and lockup control
Old 04-15-2006, 01:09 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
richard stewart 3rd
wrong thread sorry
Old 04-15-2006, 02:54 PM
Jmark's Avatar
what trans do you have now? What engine now? Lots of variables.
I'll take a guess at a V8 and a TH350. If so, the TH350 "should" have a 9" tail housing. If it does, the 700R4 is a bolt in swap. Drive shaft stays the same, cooler lines stay the same but may need metric adaptors, not sure.
Crossmember stays the same as does the mount. Shift linkage is the same but you'll need to remember where the indicator ends up since you are adding one more detent.
Kickdown cable will need to be changed to a TV cable and you MUST have it set correctly. You may or may not need a new TV cable bracket at the rear of the carb. You may or may not need to correct the carb linkage geometry, depends on what carb you are running.
Lockup can be done many ways, from a simple switch on the dash, to a vacuum operated model that kicks OD in at a set vac reading and in 4th gear only, if you buy that specific one. Again, lots of choices, all of which work.
Mark
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
55 Chevy P/U Body Mount Question bluesman123 Body - Exterior 0 02-15-2004 08:21 PM
1958-283 chevy p/u The duke of pearl Engine 2 04-04-2003 05:13 AM
Corvette rear end in a 51 Chevy p/u 3100 oldford Transmission - Rearend 2 04-30-2002 01:33 PM
Need rearend for '55 Chevy p/u? amphib Transmission - Rearend 1 01-12-2002 07:11 PM
