Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Overfill Damage
Thread: Overfill Damage
Old 01-25-2004, 06:22 AM
adtkart adtkart is offline
I wouldn't think that would have damaged the trans. The problem that occurs from overfilling a trans is that the fluid becomes aerated from the spinning parts. The same effect you get from overfilling an engine's oil. This reduces the pressures in the system because of air. It also reduces the lubrication. It sounds like you may have another problem.
