Overfilled my Chevy TH400 transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2006, 09:19 PM
HELP,
How can I get fluid out of the trans pan without dropping the pan? I tried using a hand drill powered pump, sticking a 1/4" tube into the fill tube , but was only able to get out 5 or 6 ounces before I ran the drill battery down.
I will try a larger diameter tube , but if this still won't get more trans fluid out, I need your help with other methods of removing the excess fluid.
If I end up having to drop the pan, how much fluid should I expect to add to bring the level up to the full mark?
Thanks in advance,
29guy
Old 08-10-2006, 09:21 PM
MI2600's Avatar
Member# 3287
You can drain the oil by disconnecting one of the cooler lines at the radiator. Be careful, the stuff comes out really fast!
Old 08-10-2006, 09:45 PM
MI2600,
Thanks, why didn't I think of that?
29guy
Old 08-10-2006, 09:47 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
stock pan 3 1/2 quarts
Old 08-10-2006, 10:00 PM
MI2600's Avatar
Member# 3287
Don't feel bad, 29. I felt the same way when someone told me.
Old 08-11-2006, 05:43 AM
Originally Posted by 29guy
HELP,
Thanks in advance,
29guy
I pulled the trans oil out the dip stick with a hand pump when we overfilled the trans worked fine. I think it was a orange hand pump called a rabbit. ed ke6bnl
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 10:00 PM
Th400 tailshaft problem, possibly driveline? L78Chevelle Transmission - Rearend 4 05-11-2004 07:49 AM
83 Z28 Transmission - YIKES! crandaz28 Transmission - Rearend 4 11-25-2003 07:43 AM
transmission rear end for 65 chevy truck shortwide65 Transmission - Rearend 0 05-28-2002 08:37 AM
64 chevy pickup transmission slimfatboy07 Transmission - Rearend 1 05-24-2002 07:52 AM
