Overhaul kits, whats good whats not?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2007, 06:49 PM
I am gonna do my first overhaul(rebuild) and was wondering what some of the better ones are.
It isn't apart yet so i don't know if i need a gasket set or more so what are your opinions.
I don't plan on going real high performance but maybe what i can afford.
By the way it is a 350 out of a 69 C-10, going into a 67 c-10
Old 09-04-2007, 09:22 PM
327NUT's Avatar
There are thousands of outfits selling engine kits, you just have to do your homework and decide which one suits your budget and what you really need to do. Tear the engine down and have the cyl. wall taper checked, that will tell you if it needs to be bored. If not and you're not doing a hi perf. job then rings, bearings and gaskets at the minimum. I use Speed Pro rings, Clevite bearings and Felpro gaskets. Everyone has their own recipe and favorite parts to use.....
Old 09-05-2007, 06:33 AM
cboy's Avatar
Last journal entry: Finished
I'd certainly give the PAW kits decent marks for your basic overhaul.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 09-05-2007, 06:48 AM
thanks for the input
HF tools, good or bad oldred Garage - Tools 17 11-19-2006 03:05 PM
New Member - Value of a good Big Block Allen 460 Big Block Introduce Yourself 2 07-13-2006 11:43 AM
King Bearings good? Looking for good bearings Warrant Engine 4 06-11-2006 06:50 PM
Good source for Rod Kits Tony_D Hotrodding Basics 1 05-31-2006 02:21 PM
Is there a good overhaul manual for the B.W. Super T10?? GMBrutus Transmission - Rearend 1 02-24-2004 09:05 PM
