"Overhaulin" - Lance Armstrong's Pontiac GTO - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2005, 01:53 AM
vorgath's Avatar
One question right here, if anyone has seen the show ...
They got the body sandblasted .. covered some spots with body filler .. ok so far.. the body was bright sandblasted metal shiny
Now later on they were adding a skim coat before they sent the body for primer ... BUT.. this time before they were adding the skim coat.. the body's surface was black.. or should I say.. blackened.. not shiny metal
What happened ? Obviously I missed out on something ... can anyone tell me what they actually did ???? Did they use etch before the skimcoat and primer ?
Old 02-11-2005, 06:32 AM
mrcleanr6's Avatar
i missed that episode but i can assume it was sprayed with a black epoxy primer before the filler was applied. you cant put filler over etch so it wouldn't have been that.
Old 02-11-2005, 09:09 AM
i think they put an epoxy prime on it? i saw the episode, many paint companys such as dupont, ppg etc.. have epoxy prime in grey , black and white.
Old 02-11-2005, 03:19 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
THEY SAID THEY USED POR 15.
Old 02-11-2005, 04:18 PM
vorgath's Avatar
Not POR
Not for the body, for the chassis yes, even the seats, springs etc got a good dose of POR15 .. but not the body
Thing is ... the body didn't look hmmm 100 percent smooth black... it was like someone had dyed it black .. and they never showed running over it with black epoxy primer
Old 02-12-2005, 10:35 AM
you think a guy like Chip Foose believes in Magic potions!!!
Please.....it was sprayed with epoxy primer, and BASF epoxy if I recall right...Eric
Old 02-12-2005, 12:23 PM
vorgath's Avatar
excellent
Thanks
and who said I thought he believed in magic potions anyway ?
The POR was never applied to anything but the chassis and the seat frames and springs
