overhead console in AD pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2004, 07:51 AM
guba_unus's Avatar
Learning from your mistakes
Last journal entry: CS-144 alternator
this is actually a general question because the i think the problem would exist in all cars, How do you mount a console to the ceiling of an AD pickup? I'm talking about a console with at least a CD-player in it, probably 2 small lights also. The roof metal and ceiling metal are the same, so you can't just shoot screws through it, do you make bows extending out from the reinforced areas near the windshield and doors?
Does anyone have any pictures to show how they did this?
Old 11-27-2004, 02:55 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
I'm planning on doing the same thing, but haven't gotten to it just yet.
I believe there is a mounting strip for the headliner across the roof of the truck which is located at the center ... and, of course, the weight of the overhead console will be up front, at the windshield.
Is there any kind of glue that might work?
I'm gonna post this question over at The Stovebolt Site and see if any of those guys have done this with their trucks.
Alan
54 Chevy Pickup
Old 11-27-2004, 04:30 PM
cboy's Avatar
Last journal entry: Finished
Just a small suggestion. No matter how you construct your overhead console, install some sort of venting, even it is just a few square inches where air can get in and out. CD players can run VERY hot and if the heat is trapped up there you can get some ugly results with your CD player (and possibly upholstery). One of my projects over the winter is to put a couple of vents in my '32's overhead. I'm thinking of even putting a tiny fan up there to keep the air moving.
Always learning...and sharing what I've learned.
Old 11-28-2004, 01:04 PM
horvath's Avatar
Thanks, cboy -- that's a great tip.
I got a note from someone over at the Stovebolt site:
See Here
Alan
54 Chevy Pickup
Old 11-28-2004, 01:58 PM
guba_unus's Avatar
That sounds about right for how I was thinking. I'll be installing the supports and radio over my x-mas break, probably closer to mid january, so I'll take good pictures to show how I achieved my madness.
About the fans, that is a good point, have you looked at computer fans. they are making some now that are designed to be "stealth" so that you don't really hear them running and most of them run on 12v.
Old 11-28-2004, 03:39 PM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
Guess we all have the same idea
I'm planning on putting on in my '46 Chevy Panel also. I do have a little advantage though because I've got the over the windshield console for the wipers to work off of. It will run from there to one of the ribs for the head liner. I'm doing like everyone else after that CD and dome light. Should work out alright hope you guys have good luck with yours also.
David
Old 11-28-2004, 03:44 PM
cboy's Avatar
Originally posted by guba_unus
... have you looked at computer fans. they are making some now that are designed to be "stealth" so that you don't really hear them running and most of them run on 12v.
My first thought was a computer fan but I thought they ran like 3 volts or something. Maybe someone on here has fiddled with one of these fans and hooked it directly to a 12 volt battery. I'd be interested in knowing the results.
Old 11-28-2004, 07:05 PM
horvath's Avatar
guba_unus -- looking forward to seeing those pics, bro'!
Alan
54 Chevy Pickup
Old 11-29-2004, 08:13 AM
Stinkin_V8's Avatar
Suburbanite Member
CPU fans might be 3V, but standard case fans are 12VDC - no modifications needed to use in a car.
When life hands you lemons, ask for tequila and salt
Old 11-29-2004, 09:23 AM
cboy's Avatar
Thanks for the info Aromatic_V8. Sounds like a good option. There must be a zillion of those fans in the dumpster somewhere.
Old 11-29-2004, 02:10 PM
Stinkin_V8's Avatar
Suburbanite Member
While they can be had cheaply, I would recommend spending a few bucks as guba suggested to get a quiet one. I've seen them at 12db and lower but watch the airflow vs noise - a fan that doesn't turn makes no noise at all, if you know what I mean. Some even have a temperature-controlled automatic power switch.
For optimal cooling, make sure you have an inlet and an outlet for the air.
Sounds pretty cool, keep us posted!
Old 12-06-2004, 02:17 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
Guba, be sure and add me to the list when you get some photos of your overhead consol.
Thanks
Old 01-13-2005, 01:40 PM
guba_unus's Avatar
ok, I got no finished product to show yet cause 4 weeks of winter break just aren't enough time. But I figured out how I'm going to make the mounts and I have some pictures to show the basic idea, it might be a while before I get to do much to this again. Anyways, this first picture shows just overall what one of the two support beams will look like in the top of the cab. You can see the temporary spot welds holding the shape of the angle iron at the front of the cab. Their is another bend halfway back, and judging by the light between the bar and the roof, I need to make another to get a little tighter fit. The iron is 1/8" x 3/4". I plan to have 2 pieces exactly like what you see here, I'll explain the theoretical mounting on the next post.
Old 01-13-2005, 01:45 PM
guba_unus's Avatar
ok, this picture shows the front mount. I've gotta deal with my wipers cause I wanted something absurd and impractical like wipers above the windows. Oh well, they kinda look like antenna. anyways, I plan to use a flat piece of 1/8" x 2" to bolt to the front support here. It will be shaped to match the contour of the front support. Then I'll weld the front to rear support rods to this piece.
Old 01-13-2005, 01:51 PM
guba_unus's Avatar
final picture for now. For anybody that has messed with an AD pickup, they will know about the thin headliner retainer bow "thingy" that bolts across the back of the roof. I'm going to replace this flimsy rod with a piece of angle iron, probably same stock as used for the front to rear supports, then i'll bolt it in place using the original holes for the headliner retainer. There were like 6 or 7 of them so that should spread the load out quite evenly. Then the front to back support rods will be welded to this piece.
I plan to make this something that if you undo the bolts and drop down the back first, then you could slide it out of the cab, that way it will be fully assembled before putting it in. If you have any questions, just ask me, I'll probably put together a drawing or two of this in the next week or so.
