Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - overheated engine?
Old 09-19-2004, 04:47 PM
Deuce Deuce is offline
The symptoms are
1) high temperatures
2) steaming
3) coolant going on the ground
4) use of a LOT OF bad words........
5) motor knocking or locked up
6) hissing noises
7) frying noises
I believe you meant the cure for overheating.......
1) clogged radiator
2) bad water pump
3) collapsed hoses
4) timing issues
5) restrictive exhaust
6) not enough air flow to the radiator
7) stuck or wrong range thermostat
These were not in any order......just as I typed them..........
