Overheating issue when under load? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-14-2006, 12:47 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Originally Posted by Steves66
My thermostat is a Mr. Gasket 160* and I do use a alum high volume water pump driven by the stock pulleys.
You should be running "on the thermostat" 168-170* maximum. Higher than that indicates insufficient cooling capabilities.= Your engine is producing more heat than the system can dissapate.
  #17 (permalink)
Old 09-30-2008, 08:06 PM
Mez Mez is offline
That could be your problem anything made by Mr Gasket in my opinion is JUNK!
If it says Mr gasket on it I will not buy it.
overheating flathead convert Engine 10 10-18-2013 03:59 PM
Chevy 454 overheating no matter what I do rakundig Engine 26 02-13-2011 04:03 PM
68 camaro RS w/ 454 overheating rakundig Engine 22 09-14-2006 08:52 PM
Engine load vs Manifold Vac? JohnTN Engine 2 04-08-2005 09:22 AM
overheating problem armyaj33 Hotrodding Basics 9 03-05-2004 04:31 PM
