overheating problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2004, 05:45 PM
New Member
overheating problem
i have a pont lemans w/ 389, and is overheating. i have replaced the radiator and continued having overheating, i then took out the thermostat, still overheating, the only other thing i could think of is the pump, but its fairly new, any ideas. thanks guys.
Old 02-22-2004, 05:50 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
check the sending unit and check and see if your water pump has any antifreeze out of the weep hole. or if its making a whining noise.
Old 02-22-2004, 05:57 PM
New Member
my temp gauge isnt hooked up, it overflows and you can hear gurgling noises
Old 02-22-2004, 06:06 PM
dmorris1200's Avatar
doesn't play well with others
First order of business is to get a temp gauge hooked up that works. How about a little history? Did you replace the radiator because it was overheating or did you replace the radiator and then it started overheating? Technically without a gauge you don't know for sure exactly what it is doing. Do you use an overflow tank? Did you properly burp the system after working on it? So many questions?
BUILT FORD TOUGH
Old 02-22-2004, 06:08 PM
badknuckles's Avatar
you talkin to me?
have you recently done any motor work? (intake,heads)
Old 02-22-2004, 06:20 PM
New Member
how do i burp the system, no work was done on the motor, i replaced the radiator cause it basically blew apart at the upper tank
Old 02-22-2004, 06:47 PM
And you don't think you need a gauge immediately??? It's like a doctor diagnosing a heart condition without ever taking your blood pressure, pulse, etc.. Did you literally blow apart the radiator or did it rot out?
Ok I just noticed you probably accidentally started a new thread with a response about the radiator. Sounds like you said it failed from old age (rotted out maybe, bad core). Any time a cooling system is opened up the system needs to be 'burped' to remove any air pockets that may be trapped in the engine. I would think most repair manuals would go through this procedure. You may just be airbound, but like I said you are asking for doctors to diagnose a sick patient with no medical records.
BUILT FORD TOUGH
Old 02-22-2004, 06:48 PM
DoubleVision's Avatar
First off, put the thermostat back in, then go over the system, how to burp the system is to make sure a overflow system is attached to the radiator right underneith the radiator cap into the resevour, this must be in place, otherwise it`ll overheat, also, did the car come with a air dam underneth the front end? make sure it`s there or it`ll overheat, make sure the radiator hoses aren`t collapsing check to see that there is a spring installed. and by all means get a temp gauge, it`s the life line to your engine.
Old 03-04-2004, 07:58 PM
New Member
its still overheating
i put a temp gauge on it and while it idled it got to 210 and i turned it off, i dont have a thermostat in it, any ideas?
Old 03-05-2004, 04:31 PM
New Member
still hot
once i killed the engine i checked the top radiator hose and it was still cold, i also felt the heater hose coming off the waterpump that is redirected to back of the block and it was also cold...does this mean my waterpump is bad?????
