Overheating and runs rich - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2007, 10:59 AM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
I've got a '78 350 SBC in my '46 Chevy Panel and now for some reason it's running hot. It was holding at 195 on short to medium runs around town but now it's going to 205/210, don't want to run it any higher. I had a 180 stat in it and dropped it to a 160,it helped a little but just took longer to start to overheat. I'm also using the stock copper and brass rad. I know I could do better with that but funds in the way. The fan is a 17" electric with 2700cfm. Now it runs real rich and need to change the jets in the carb, 625 cfm Road Demon. Could the rich condition be the cause of the over heating?
Old 06-11-2007, 11:27 AM
Yes! Running rich will make one overheat. And lowering the temperature of the T-stat won't make one run cooler. Once the T-stat opens you are gonna get what you get as far as temperature!
Old 06-11-2007, 12:36 PM
T-bucket23's Avatar
Wiki Edits: 26
Generally lean mixtures will cause overheating not rich mixtures. Have you checked your ignition timing. Late ignition timing will also cause overheating and could give the impression of rich mixture due to incomplete combustion.
Check the timing with a good light. 8-12 before is a good starting point on most SBC engines.
Changing the thermostat is not the answer, it will just over heat slower as you experienced.
Old 06-11-2007, 01:33 PM
Opps! My Bad! Sorry! In my thought process to hurry up and be the first I really made an ***** out of myself! Oh well, what's new?
Old 06-11-2007, 05:58 PM
Overheating while the vehicle is in motion is a classic symptom of insufficient coolant flow thru the radiator or one that is too small for the job at hand. Cleaning the radiator at a competent shop that can "rod" the core is the inexpensive solution. The copper/brass and lead based solder that hold it together react in the presence of water, whether that water is diluted with anti freeze or not. The reaction also includes the cast iron of the engine and if you have aluminum heads they get into it big time.
Anyway, the corrosion acts in two ways, one it removes the softer materials which will eventually result in a leak. Two, it deposits materials which cause the tubes to become plugged, thus reducing flow. Rodding the core takes these deposits out. It doesn't solve the decay problem, however, it could buy you some time.
Barring that being a successful fix a new radiator will be in order to solve the problem.
Bogie
1967 pontiac 455 overheating brisk Engine 11 04-03-2008 11:17 PM
overheating problem billszoo1 Engine 26 01-24-2006 06:22 PM
overheating 454 everett Introduce Yourself 2 08-29-2004 09:41 AM
SBC Overheating, Any Ideas lakeroadster Engine 3 05-08-2003 07:07 PM
overheating running like s##t 53buick Engine 1 08-18-2002 07:47 PM
