overheating - unable to get air out of my cooling system - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2008, 03:23 PM
i think thats the problem atleast. Its a 350 with a 671 weiand blower and I've been having problems with it overheating. I have a huge aluminum radiator, aluminum high flow water pump and a flex fan. I have another 67 camaro with a similar fan setup, except it has a factory radiator and no heater core...that car never overheats.
I was wondering what the proper way to get the air out of the cooling system is? I let it get up to temp with the radiator cap off and it started spewing tons of coolant out of the radiator and i immediately turned it off.
Old 07-17-2008, 03:43 PM
T-bucket23's Avatar
Wiki Edits: 26
Do you have a shroud, if not you need one.
dawg's Avatar
NAVY VETERAN
I saw this post on team camaro aswell.
to fill the system I usually fill the radiator to near the top.
I also remove the upper hose at the radiator and fill the block(works for high flow thermostats)
it will take a bit to fill that btw cuz there is small holes.
Or if you have a flush kit instaled you can crack the cap to expell air from there.(air goes to the highest point of the cooling system)
once filled I turn heater full on to get air outta there.
Im almost positive you probly got a lower hose that is collapsing on ya.
Old 07-17-2008, 04:47 PM
You probably don't need a high flow pump. Given these things are hardly, if, ever rated in gallons per minute at specific RPMs it's always hard to impossible to tell what the delivery is compared to any other pump. This is a place where more isn't necessiarly better. For competition engines that see long duration high RPMs, it is not uncommon to reduce the size of the pump impellers or remove some of them to reduce the high speed flow to something that doesn't blow coolant out everywhere.
Typically street/strip engine temperature is controlled by a thermostat. This immediatly tells you that the pump and radiator have excess cooling capacity and that the variable restriction of the thermostat reduces the velocity and amount of return coolant from the engine to the radiator, thus managing engine temperature.
Competition engines usually use a fixed orifice to achive a consistent temperature once the motor is warmed up. This is a cut and try process that will vary the size of the orifice depending on operating environment and engine speed.
Running a high volume pump without any means to manage coolant flow will always result in coolant blowing out of the radiator if the engine is run with the cap removed.
If you can't get the system bled of trapped air, you can assume:
1. The air is really steam from internal overheating spots or the result of pump cavitation.
----or-----
2. There is a blown head gasket, which is a real possibility with a blower, and you're seeing mixture being blowing into the cooling system.
Bogie
Old 07-18-2008, 09:30 PM
If you are blowing coolant out of a crossflow radiator you have a serious problem. The cap is on the cold side of the core.
Are you getting 25* drop across the radiator when the coolant is getting hot?
Check with an infrared thermometer.
Remember, any big radiator requires an overdriven water pump or high flow pump to keep tube turbulence for coolant transfer.
MOST flex fans are of limited cooling value. I strongly suggest a stock type 7 blade with thermostatic fan clutch.
S10 Air conditioner upgrade Stonebrier 2 General Rodding Tech 27 08-09-2009 05:57 PM
wiki update: Bulletproof cooling system Jon Engine 0 06-12-2008 03:05 PM
one giant orange peel flamedfordbronco Body - Exterior 14 06-20-2007 09:04 PM
air in cooling system markiemyster Engine 5 03-04-2006 03:34 PM
fabricating a cold air induction system? stfinney Engine 5 12-12-2002 09:37 PM
