I strongly recommend you don't permanently Mount your portable equipment on the 3x3s. I guarantee that when you finally move in, you will want to rearrange your floor space 'cause it always looks different in real life than on paper and if the equipment is fixed to the floor, you will be very frustrated. Also, you may need to convert the space to an appartment for Aunt Bertha and she may not want a 6" grinder in front of the big screen!
The way I handle my pedestal mounted machinery is to build my own pedestals. I get an old wheel from the junk yard and cut off 1/2 of the rim leaving the web looking up and the remaining rim looking down. Then I weld a 3" round pipe for the pedestal in the middle of the wheel web. Turn the wheel over and weld a few 1/2" rebars across the inside of the wheel rim to anchor cement, then fill the cavity with cement, flush with the bottom of the rim. Then stand the unit up on its base and put a smooth cement dome on the top so stuff will cascade off and not collect. You can get fancy by embedding conduit inside the post and integrating a starter switch in the post. Weld a plate on top to mount the machinery, paint it purty and you will have a stable, portable, good looking tool pedestal that cost nearly nothing.
