Overspray? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2005, 03:35 PM
Overspray?
Guys, I will bother you till I'm done with my 67 Camaro painting process done.
What is the trick when sparaying not to have any overspray? When I was spraying my 2K and epoxy I saw some overspray, What is the trick to not to have? Any comments welcome. Thanks as allways.
Old 09-09-2005, 03:41 PM
BarryK's Avatar
Its not totally controllable.
Of course if your using an HVLP you will have less overspray.
You will have less when you spray primer and base as you use lower air pressure.
Clear will be the worst as you use higher air pressure.
Cover anything you want to protect as its easier to do now than clean it off later. Lots of plastic sheeting.
Old 09-09-2005, 04:38 PM
rrmccabe's Avatar
GM Muscle
Barry is right (as usual).
I am doing a 67 also and I have sanded more overspray than I care to admit. It gets everywhere. Sanding INSIDE doors, etc is no fun.
I like the plastic masking material you buy. Mine is 3M and 16' wide. Its easy to wrap around stuff and does a great job. So mask everyhthing.
Its all work !
Old 09-09-2005, 05:18 PM
There is always overspray. If you have a conventional gun cranked up to 50 p.s.i. spraying clear, there is lots of it. It is very important that you have proper ventilation in the area you are spraying, hvlp or not. Nasty stuff is in the hardeners, so make sure you cover exposed skin, eyes, and have the proper respirator. Hard to enjoy a newly painted ride if you ruin your health, blow the place up or worst. Don't want to scare you but just want to keep that part drilled in peoples heads. Many people have not followed saftey, myself included, but there is always the chance of severe consequences of both igniting fumes or getting overexposure and ruining your health or possibly not waking up in the morning.
Old 09-09-2005, 05:46 PM
rrmccabe's Avatar
GM Muscle
Hahaha. And what would be worse?
I think if I ruined my health AND blew up my garage that would pretty much be it !
Old 09-09-2005, 06:27 PM
To reduce overspray inside the doorjambs and between the fenders and hood, I always use a round foam tape. If you use foam tape when spraying primer, you should replace it before painting.
Also make sure everything is taped properly and that it will resist the pressure of the gun. Using a "tack rag" between each coats of base coat and before the clear is also a good thing. Don't use the "tack rag" between coats of clear .
A last solution that could help reducing overspray is to paint the car with base coat and to clear each part at a time (hood, fenders, doors, top) when the rest of the car is taped. I never tried this method but I think it could work pretty well but you would have to use a lot of masking paper and tape.
Good luck on your paint job.
Old 09-09-2005, 10:58 PM
Bad would be if you blew up your garage or got too much exposure to iso's and chemicals. Worst would be if you were in the garage while it happened, or got enough exposure the iso's to kill you. I don't remember the whole story but read about a guy who painted a car and felt sick that day. Next morning he didn't wake up.
Old 09-10-2005, 07:43 AM
rrmccabe's Avatar
GM Muscle
Kenseth17, you are way to serious today.
I was kidding
Old 09-10-2005, 10:11 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Good ventilation helps too. Getting overspray out of the area will prevent it from being available to settle on anything. It's a problem for sure and an ounce of prevention is a big step in preventing it.
I use the cheap thin plastic "drop cloth's" to drape over area's that are tough to mask off/out like interior's,engine compartments/engine's taping where necessary and just toss it when done,It's cheap and much easier to use for some things than paper. Old sheet's and trash bag's are good as well.
Painting in pieces. Can I do it? rrmccabe Body - Exterior 33 11-09-2005 08:37 AM
How can I lay this clear without getting overspray? Pic BUSAFREAK Body - Exterior 6 04-30-2005 08:46 PM
overspray on my engine block lonewolf3197 Engine 11 07-05-2004 11:38 PM
Painting kf6myv Body - Exterior 7 09-17-2003 02:31 PM
