ow do I check my ecm to see if it is a 350 ecm - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2006, 09:16 PM
The writing on the box says
SERV. NO. 1227747
863341 M710612516
ADTR
Suppose to be out of a Suburban 2wd 350 auto Can anyone tell me if this is right ?.. or a way to open it and read the chips to identify thanx
Old 12-27-2006, 09:35 PM
edge's Avatar
Time is short, are you ready?
Get the Broadcast Number off of the EPROM. It is a four letter code similar to the one pictured below. The EPROM is the one with the light blue cover.
Knowing the broadcast code will help determine your question.
Ed
Old 12-27-2006, 09:46 PM
Re eprom 350 or not..
It has ADTR the small chip has
16060837
DELCO ADTR 3432
Old 12-27-2006, 09:51 PM
The other ECM I have here that may have got mixed up is
1227747 ACSU which comes up as a 350 tbi LO5 1990 chev van but I got it from an 88 suburban
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
Where is the best place to find a 350 engine Andrew7dg Engine 8 10-20-2005 05:28 PM
4x4 700R4 to 350 swap Davesblazer87 Transmission - Rearend 4 12-22-2003 08:59 PM
305 vs. 350 question DesertPanel General Rodding Tech 4 10-16-2003 09:19 PM
350 block pre-purchase checklist idrva55 Engine 4 01-05-2003 11:52 PM
