ow do you take off a torsion bar off, to replace lower control arm? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2009, 04:03 PM
bigno09's Avatar
I have a 92 chevy suburban, wrecked it about a year ago, I put it back togather. I put it on the alignment rack, the A/S/I says the lower control arm is bent, but to replace it, you have to take the tension off the torsion bar!!! I was wondering if any one has so knowledge on this, and how to I get the ride height back even with other side after the job is done.
Old 11-04-2009, 08:29 AM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Note the ride height before you start. Remove the front shocks and let the suspension droop. Loosen the height adjustment bolts on the levers at the end of the springs opposite the control arm (under the crossmember at the rear of the transmission). Remove the crossmember and the torsion bar keys from the ends of the springs, and then the springs will slide out of the a-arms.
Use the bolts on the crossmember to the torsion keys to reset your ride height when you are done.
Andy
Old 11-04-2009, 09:19 PM
you might want to put a C clamp on the key before you remove the adjustment bolt. As the torsion bars are under pressure, and like he said just count how many turns it takes to remove the bolt.
Old 11-04-2009, 09:22 PM
life is a temporary assignment
If you let the front wheels hang, there's not to much pressure on them..
I just changed my a-arm's on my 2000 Yukon,And never had to touch the adjustment bolt, until I went back together.. Just to keep it in the little notch the bolt fit in..
Not too sure how much different the 92's are...
Rear Lower Control Arms, best choice? BUFFALOBILLPATRICK Suspension - Brakes - Steering 4 02-06-2009 01:43 PM
1972 El Camino Control Arm question jaster Suspension - Brakes - Steering 4 09-11-2007 02:39 PM
control arm mounting problems. leldai73 Suspension - Brakes - Steering 14 08-17-2007 04:13 PM
upper control arm 67 C10 wickedwitchinak Suspension - Brakes - Steering 1 12-20-2004 10:47 PM
Help!!! Control arm bushings! arborlis Suspension - Brakes - Steering 5 03-22-2003 06:57 PM
