oxidation on chrome help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2006, 08:15 PM
hello all,
can anyone tell me how to remove oxidation on chrome and liscence plate frames, they are aluminum and really dull looking. i have tryed rubbing compound chrome polish, paint thinner etc.thanks in advance dirtslingerrc.
Old 07-14-2006, 09:43 AM
CARB TECH
Weanol
Hi my name is Tom. I've come across some situations like that before. If you can come across a truck that sells items for auto detail shops, pick up a can of Weanol. Its expensive but it works better than anything on the market. Its a cream that will take off corrosion off polished aluminum wheels, oxidation from chrome, etc....
I bought a 50oz can of it and it has lasted me 5 years, I paid $85 for it but it works real good. all you do is rub it on like you would rubbing compound until it turns black, then buff it off real good with a 100% cotton cloth and it should come out sparkling clean. Give that a try and good luck.
Tom Lyannas
Las Cruces, New Mexico
Old 07-14-2006, 10:40 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Mothers California Gold makes a aluminum cleaner and polish that works really good. A small can of it is about 5 bucks at Auto-Zone. I cleaned and shined up my diamond plate aluminum tool box with it......It was badly oxidized, but now it looks like new again.
Old 07-14-2006, 11:20 AM
CARB TECH
Weanol
Check on the can to see if it works on chrome plating or clear coating on aluminum wheels because sometimes it won't, but don't get me wrong Mothers is a real good brand name polish but if you can get a hold of some Weanol, you will really see the difference.
Thanks for the reply,
Tom Lyannas
Old 07-14-2006, 07:48 PM
thanks,,tom and henry/// i,ll try the 5.00 stuff and the weanol if i have to 85.00 is high// but all that chrome is a lot more . sounds good thanks RC
Old 07-14-2006, 10:41 PM
comet boy's Avatar
When all else fails burn it
Last journal entry: more hiding stuff
You can always use steel wool and glass cleaner to clean it. Like really fine steel wool that won't sratch.
Old 07-14-2006, 10:47 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
You can also buy a lil kit at Lowes that has 3 different kinds of compound, 3 different size wheels and a attachment for a drill. You can polish anything with this kit! Its only about 7 bucks.
Old 07-15-2006, 07:10 PM
hey,, thanks alot, now i have a lot of possiible solutions there,s nothing like good free advice :
Old 07-16-2006, 06:07 PM
Last journal entry: frame build
best advice I can offer is don't use steel wool on your chrome or aluminum. The fine pieces of steel wool will imbed in the metal then you have rust streaks in addition to the oxidation. Get some 0000 or finer brass wool at Menards. Scrub it with mothers andthe wool then do it again with a soft cotton cloth.
Old 07-16-2006, 07:58 PM
weirdbeard's Avatar
1976 Ranchero GT
Right on! A friend of mine did an old lightly rusted motorcycle with triple alt. It looked really great until it spent a lil time outside.
Old 07-17-2006, 07:25 PM
roger1's Avatar
I don't do it with aluminum but I have used Brillo/S.O.S pads wet on chrome and it works great for this.
I can't imagine any imbedded steel doing this unless there where places where the chrome was peeling.
Chrome Plating Warning R. Builder Hotrodders' Lounge 5 06-22-2006 08:05 PM
removing/painting over chrome that is pot metal? 72helpneeded Body - Exterior 7 05-27-2006 09:09 PM
Chrome water pump 49dream Engine 12 11-16-2004 05:17 PM
Painting chrome wp442 Body - Exterior 5 12-14-2003 10:35 AM
chrome paint? not painting chrome CustomChrome Body - Exterior 14 10-21-2003 08:44 PM
