Originally Posted by chadmw7
Should I keep upping the acet and then matching it with O2 until it does the job or try something else? How far should I open up the valves?(on the torch, not the tanks) Can I literally keep going until the torch valves are wide open or is that dangerous(this is all assuming that the tank regulators are set at 5-6psi each.
Whether or not you need to increase the pressure will be determined by your tip/hose size so we need that info before making any suggestions about that.
