Oxy Acetylene Info Needed - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 08-25-2009, 10:53 AM
Right, obviously if 4 PSI would not deliver enough volume for a given tip size with the control knob wide open then higher pressure would make a lot of difference. On the other hand if 5 PSI (just an example) was capable of delivering twice the volume needed then turning it down would only have the effect of needing to open the control knob a little more. I know some people have argued that it is volume plus pressure that determines the flame characteristics and of course this is true but the pressure in the mixing chamber is going to be the same for a given volume and flame setting regardless of regulator setting, assuming the regulator is set high enough to deliver sufficient volume. The control knob, while being nothing more than a "choke" valve will serve as a pressure control regulator for the discharge (mixing chamber) side as long as the input pressure remains constant, which it will due to the tank regulator maintaining a constant pressure on the hose. In the interest of safety however it is best to use the lowest setting that produces the right flame without having to open the control knob more than 1/2 to 3/4 of a turn. It also makes it easier to adjust the flame when using lower pressure because the higher the pressure then the less a control knob will have to be opened to make a difference in flow making it much more "touchy".
The reason this is important is that it seems when someone is having trouble welding it is often suggested to use different regulator settings when in fact that is rarely a problem. When using a cutting torch the fuel side is about like the welding setting, it simply requires enough volume to produce the desired flame so set the regulator to a reasonably low pressure that will supply just the right volume without excess hose pressure. The Oxygen side when cutting is a whole 'nother story however and settings for Oxygen regulators for cutting is very important and small changes make a big difference.
  #32 (permalink)
Old 08-25-2009, 08:08 PM
Oxy/Acetylene welding
The pressure on the regulators is not all that important as long as you have enough flow for the thickness of the metal you are trying to weld, the valves on the torch are there to adjust so you get a neutral flame (equal amount of oxygen and acetylene) for welding carbon steel.
  #33 (permalink)
Old 08-25-2009, 10:20 PM
Wiki Edits: 27
preheating
I have a set of Y's so I can use 2 sets of hoses. one for the welding head and one set for the cutting torch... makes it easier to pre heat heavy stuff. I've seen guys get a lot of popping because they are using too large of a tip for the job. they turn down the torch and the flame travel is faster than the gas flow so the flame can travel back up the torch. and pop. I'am going to print an hang the hooper charts in the shop for the kids to read.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Oxy Acetylene Questions..... crazy larry General Rodding Tech 10 11-10-2011 03:05 PM
87 s10 2.8 v6 to 3.4 v6 crate engine swap info needed 87sdime4x4 Engine 1 07-23-2006 07:15 PM
Frame Swapping Info needed TexasHardcore General Rodding Tech 8 07-05-2006 10:17 PM
Machining Info. Needed GoneNova/406 Engine 10 06-22-2006 08:22 PM
Pontiac head # 6x info needed for 455 cu.in D.Cantrelle Engine 6 09-03-2004 07:13 AM
