oxygen sensor - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2012, 01:22 PM
oxygen sensor
Should the oxygen sensor be hot even when engine is off for 24 hours?
Old 01-06-2012, 12:23 PM
no it should not. If it has three or more wires to it then it has an electric heater built into it that should not work without the ignition being on. the ignition supplies 12 volts to the heater and the computer grounds it to cause it to heat up until the engine runs enough to heat the sensors. Check to see if your ignition is hung on for some reason.
Old 01-06-2012, 02:36 PM
Yes I just checked for 12 volts on the harness and in fact I am getting the 12 volts when the key is off.
Deleting an oxygen sensor? crussell85 Engine 5 04-24-2011 04:51 PM
oxygen sensor issues steelnuts Engine 3 07-21-2010 10:03 AM
Exhaust leak or oxygen sensor? vortmax Engine 10 04-18-2010 06:01 PM
Oxygen sensor JohnyR17 Engine 10 03-26-2005 09:19 AM
Oxygen Sensor Crown Vic Police Engine 2 09-02-2003 07:48 AM
