p/b 727 torqueflight transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2013, 11:26 AM
old street rodder
Installed deep oil pan on my p/b 727 torqueflite transmission.How much should be cut off dipstick tube to make dipstick read right?
Old 06-10-2013, 12:50 PM
WDCreech's Avatar
Grumpy Old Goat Herder
The dipstick should read right no matter what pan you use. If you wanted it to have only the same amount, you would need a longer dip stick.
Old 06-10-2013, 06:58 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
I'll second that fact
Jester
Old 06-11-2013, 01:02 AM
Wiki Edits: 85
Originally Posted by jim ellis View Post
installed deep oil pan on my p/b 727 torqueflite transmission.how much should be cut off dipstick tube to make dipstick read right?
none!!!!!!
Old 06-11-2013, 04:46 AM
how much deeper is your new pan
Old 06-12-2013, 10:17 AM
This has nothing to do with your question but if you installed a used deep pan you bought some where you need a filter (pick up) extension!!!! just in case you didn't get one with your pan !!!!! This is very important or you will destroy your trans.
Jester
727 Torqueflight kickdown rod javracer Transmission - Rearend 4 07-29-2009 05:20 PM
Mopar 727 TorqueFlight question Steves66 Transmission - Rearend 1 08-05-2006 07:48 AM
727 Torqueflight Mopar transmission fluid mitmaks Transmission - Rearend 2 03-25-2005 06:50 PM
727 Torqueflight transmission Dan McCauley Introduce Yourself 2 12-07-2004 06:05 PM
727 Torqueflight shift kit 1meancuda Transmission - Rearend 3 02-04-2002 08:24 PM
