p s sterring - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2008, 08:42 PM
steve t's Avatar
ex biker, now hotrodder
power steering lines //////////////////////////////////////
hello, i just try to put org power sterring on my 61 impala, having clearing problems with 90 degree elbow hose fitting on control valve. they are hitting frame or crank pulley when turn left or right, anybody else have thight fit,
Old 10-27-2008, 07:17 PM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
Can you use a smaller belt and bring the pump closer to the center?
Old 10-27-2008, 08:28 PM
Wiki Edits: 27
chevy
It seems like the steering pitman arm and idler were different for power and non power. guys used to mix and match parts to get more clearance when changing engines...500 caddy swap I think it was
Power Sterring Pump Removal fatboy1995 Suspension - Brakes - Steering 5 06-14-2007 11:32 PM
Power sterring pump question willowbilly3 Suspension - Brakes - Steering 4 07-27-2006 07:02 PM
Sterring Column Rebuild 68novafan Suspension - Brakes - Steering 3 07-27-2006 06:07 PM
installingn power sterring In_Style Suspension - Brakes - Steering 1 06-16-2005 08:42 PM
67 nova power sterring not power assist? turbonova Suspension - Brakes - Steering 6 12-20-2004 07:52 PM
