p/u coil - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2005, 01:08 AM
DJC DJC is offline
p/u coil
Replaced p/u coil on '93 1/2 ton gmc 350 and now running hot and won't shift properly, what did I do wrong?
Old 02-12-2005, 01:17 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Welcome to the board. You are new so donít know the ins and outs yet. This forum is intended for general introductions only. Tech questions posted here donít get the coverage they deserve. Repost your question in the proper forum and it will have a good chance of being answered.
Old 02-12-2005, 03:49 PM
poncho62's Avatar
Wiki Edits: 5
Moving this to the tranny forum, you will get a better respnse there............
Old 02-12-2005, 03:55 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
vacuum leak
Possibly pulled the PCV valve hose out of the carb or some other vacuum line got disconnected.
Old 02-12-2005, 10:10 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
running hot could be the timing is retarded.
A 93 truck should have a 4L60E tranny. Is the TPS on the throttle body moved or damaged or un plugged
