P to V Clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2004, 07:14 AM
84 Z28 Convertible
P to V Clearance
I'm ready to install my heads to check the P to V Clearance. I have 2 brand new Fel-pro 1014 gaskets to be used with the heads. Is it possible to reuse these gasket after torquing about four bolts to set my clearances? I know I can mock it with no gasket and add the .039 thickness and figure P to V clearance, but I would like to mock it with the exact assembly and leave less room for error.
Old 05-18-2004, 07:48 AM
Your fine. . .
