P1345 code 1996 gmc truck - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 06-01-2013, 01:47 PM
what type of scaner do I need to set dist. timing and what is the cost of this device?
Old 06-01-2013, 02:23 PM
You can't set distributor timing - the computer does that. Changing the distributor position will change the cam position sensor phasing, but the computer uses the crank position sensor to trigger the ignition unless that sensor has failed and it has defaulted to a backup mode. The cam position sensor is mainly used to tell the computer when a given cylinder is on the compression or exhaust stroke, and to sense a misfire. The computer reads changes in the relative position of the cam and crank sensors to detect a misfire.
Old 06-01-2013, 03:00 PM
Incorrect. The P1345 is cam/crank correlation code and has to be within +/- 2 degrees or the code will set. The adjustment is made by turning the distributor and observing the advance on the scanner. You will only have about 15 degrees? or so total adjustment. If it's still not within range, you'll have to pull the distributor back out and readjust a tooth forward or backward.
I can't say what the cheapest scanner that can read the cam/crank correlation, but you may want to pay a professional to be responsible for this job. May wind up being cheaper and less of a headache for you.
Old 06-01-2013, 03:43 PM
Banned
ditto, how many miles on the truck, if you haven't moved the distributor at all, it might be the timing chain is worn/loose
Old 06-01-2013, 04:37 PM
LATECH's Avatar
If the distributor hasnt been removed, and the code is coming up, it is most likely a worn dizzy gear.
You will need a good scanner wi Bi directional controls to perform the cam/crank position relearn . And thats after you repair the reason why it set.
As stated before, check timing chain slack.Then I would be suspect of the dizzy gear. They seem to wear fast, and it may not look to bad to you, but to the trained tech.....
Fact is stranger than Fiction
Recent Modern Electronic Engines posts with photos
98 Tahoe 4x4 5.7L mil code P1345, but fuel meter is flooding cylinders? mike 96 ws6 Modern Electronic Engines 10 04-03-2012 05:08 PM
P1345 code newly built 96 chevy 350 now 383 headers red chucksrt Engine 18 09-19-2011 05:45 PM
1996 GMC truck with 4L60e smashed magnet in pan Dice07 Transmission - Rearend 4 08-09-2009 01:36 PM
Code P1345 77flaredout Electrical 2 03-11-2006 02:02 PM
1996 Pontiac Trans AM Paint Color Code ? 64Joker Body - Exterior 4 04-07-2005 05:38 PM
