p14010208 casting numbers on a chev engine? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2013, 02:55 PM
Is 14010208 casting numbers on a chev 1973-1987 style a 350 or a 305? because peoples telling me its a 305 in wich this motor came out of a 3/4 ton 4x4
Old 01-31-2013, 04:24 PM
DoubleVision's Avatar
There is no casting number that ends in 208, however you likely have the 8 mistaken for a 9, and thus, the correct number which is:
1980-85 14010209 350 - - 4 truck
Old 01-31-2013, 04:55 PM
please tell me
Can you look at that casting number again. I see a 14010280 but not 14010208. If it is a 14010203 then it is a 1980-85 305. If it is a 14010280 it is a 267 block.
Old 02-01-2013, 02:57 PM
I can't get a really good id on this casting but it looks legit as a Canadian casting. Look at the stamped number on the right block just ahead of the right cylinder head. This is the id of the built engine not just the block casting number that you showed us. Another key that can unravel this is the cylinder head casting number which are located about the middle of the head with the rocker cover removed.
Bogie
Old 02-01-2013, 04:05 PM
305 or 350
Bogie's right, check the head casting number under the valve cover. Best and easiest place to start. Usually not a problem reading that number with the cover off.
Engine casting numbers and vin numbers drfo Engine 5 06-18-2010 05:15 PM
Chev 6 cyl casting numbers DanoMontana Engine 6 02-14-2007 10:49 AM
engine casting numbers 62chevystepside Engine 3 02-20-2006 12:11 PM
Engine Casting Numbers Tponykid Engine 1 07-08-2003 09:14 PM
Engine I.D casting numbers Auto Engine 8 06-12-2003 08:56 PM
