Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - p1860 tcc pwm solenoid electrical fault
Old 06-07-2012, 08:50 PM
LATECH's Avatar
LATECH LATECH is offline
The solenoid should have a resistance of 10-16 ohms.
Be sure the trans fuse is not blown.If it is then there is a short to ground which may be intermittent .
Could also be short or open in wiring from PCM to solenoid
PCM could be faulty
Fact is stranger than Fiction
