Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - p1860 tcc pwm solenoid electrical fault
Old 06-07-2012, 09:45 PM
2drtahoe4x4 2drtahoe4x4 is offline
Wouldn't the ignition cause more problems then just the p1860 code? If not is there a way I can test to see if its good or bad? Trans fuse is good. I'll check the solenoid tomorrow. If that's good I guess its onto checking wires. Thanks for the quick replies.
