only 2 symptoms occur intermittant hard starting and fuel gauge acting wierd the switch controlls current to the ecm. most gm vehicals that come to my shop with a 1860 code it is in the ignition switch not the lock were the key goes the switch is on th e bottom of the column but check basics fuse and trace the wiring
