Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - p1860 tcc pwm solenoid electrical fault
Old 06-09-2012, 08:44 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
Originally Posted by 2drtahoe4x4
Sorry for the misunderstanding. Could you please elaborate on this switch as I'm not familiar with it. So if you could let me know what I'm looking for and how to test it that would be great. I traced the tcc pwm solenoid wiring back to the computer and when I unplug and ground it the solenoid works. So maybe a problem in the pcm? Thanks again for all the help.
NAPA Echlin # KS6201
This what the ignition switch should look like. It's not the type mounted down the column, and controlled by a rod.
I almost hope this isn't your problem, because it retails for about $400.00 here in Alberta Canada.
