I had an old crimper from Radio Shack that I used to crimp Packard 56 terminals before I soldered them. They did a nice job of making a good mechanical connection and the solder "sealed the deal".
Being a $10 tool purchased 20 years ago, it finally wore out, but the new version of it that Radio Shack sells will not accept a Packard 56 terminal (jaws aren't large enough, so it's no longer an option. Just crimping with pliers makes it difficult to push the crimped terminals into the housing since I can never get them squeezed small enough and the crimp always looks crappy . And since I also do some restoration work, I don't always have the option of switching to a different type of connector.
The pro-quality tools are $200+ and I'll get one if I have no other choice, but is anybody aware of a more sensibly priced crimper that can be used on Packard 56 terminals?
Ebay Ratcheting crimper - I picked this up and haven't looked back. Best $80 I've spent on electrical tools so far. I believe it's die #18922 that does that terminal type (Packard 56 & 59, Pack-Con II & III, Metripak's, etc.).
You mean where it bends the tabs in towards the center of the wire? In that case, then yes it does. Does both sets of tabs (the contact and the wire support) in one shot, too. I can take some pics when I get home tonight and post 'em up tomorrow if you're interested in better pics.
Napa part number 726-603. Thats in their Belden line. I use them for just about every roll style crimp I've needed. MSD also sells one. Part number is 35051.
I have no idea what a Packard 56 terminal is, but I use this tool (below) for most all of my crimps, in the car, on my job and on boats. It used to be about 20 bucks or so, and you can get it at HD.
Packard 56 is the terminal line used by GM during the 60s and 70s for virtually all of their wire harness connectors. A normal crimping tool for barrel type terminals will not crimp these correctly, causing distortion and preventing the terminal from fitting in the connector body.
Packard 56's are probably the most common terminal on older GM (at least) wiring. It's the 1/4" blade connector, either male or female - Used for stuff like back of gauge pods, tail light sockets, heater control, etc.
Packard 59's are the larger cousins of Packard 56's. Mainly used for headlight sockets and other high-draw applications.
Pack-Con II's are edge-connect type terminals. Used in the steering column harmonica connector, and some other places like wiper switch and such.
Pack-Con III's are the heavier-duty version of Pack-Con II's. Mainly used in the fuse panel itself to connect to the fuses.
This has been a really good thread. I just wanted to chime in and thank Brimstone for the referral. I ordered one of these a few days ago, recieved it Tuesday, and tried it out on Wednesday evening. The first crimp didn't come out correctly, because the terminal was not properly seated in the die set. Several other terminals, however, all came out beautifully. To my (unprofessional) eye, they look machine-made. This is a really nice tool. Thanks again, Brimstone.
Glad you like it! I know that there are larger sets out there that use the same pliers frame, but this kit contains almost all the dies that would be needed for an older-type electrical work (There is a die set specifically for spark plug wires that I had picked up as well). I mean some of the kits have like 20-some-odd jaw sets to cover everything from tel-com work (Cat-V/phone connectors), to cable co-ax to automotive to A/V connectors and probably more, but those are also significantly more expensive.
DelCity.net is a great source for all crimping tools as well as connectors for a myriad of electrical needs. Prices are VERY good and selection is awesome.
Searching for a 12-gauge wire on Amazon and Ancor Marine Grade Primary Wire seems very popular. Individual copper strands and tinned for marine use. - Will Packard 56 flat male terminal work on this wire?
Maybe too soft?
And I mentioned wrong MSD jaw.
Some mentions that MSD 3506 jaw works. But the ad say “amp pin” ?
I need terminals and I think it is Delphi 2971859 metric-pack male loose terminal.
Not sure what they mean with loose terminal?
And, this 12 GA doesn't have the rear metal wings like the others.
Will it lock into my firewall contact even without these wings?
1) Those are NOT "metri-pack". Those are Packard 56 male terminals. Metri-pack looks like this:
2) The terminals can come loose (individual parts) or on a strip for automatic feeder use. You want the loose ones.
3) The "wings" help align the terminal correctly in the plastic connector body. All genuine Packard 56 male terminals have them. They are not 100% necessary for terminal retention, however. The "tooth" on the blade does that. The Chinesium versions often do not have the wings. Note that sometimes the wings can interfere with the crimper jaws, so not having them isn't necessarily a bad thing.
Oh okay, Thanks.
I thought Delphi was genuine. And maybe 12-10 gauge was too large to have the “wings”. YearOnes Power feed wire for all H.E.I. made with 12 gauge seems to use this wing-free terminal.
I haven’t seen any 11AWG terminal, can I use the 12AWG or 10AWG for my 10AWG wire?
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
