wheel bearings
after cleaning i spray them with brake clean or gum cutter to remove any of the parts cleaner before packing them
In a Detroit Allison class that I was in, some time ago, they advised us NOT to use compressed air to blow the bearings off. They just told us to clean the grease off, inspect and repack. I, too, think it's a time thing now.
How can you give it a good inspection for wear as stated earlier ![]() Jester |
Whaaat?
If there is any "fun" in repacking bearings, it's in the cleaning and blowing them dry. ![]() No, I have never "wound them right up to warp factor 7" ... always have used a bit of drag to keep the speed down. Right or wrong, it's never caused any trouble, and bearings were always replaced if there were ANY visible defects in either the cone or the cup. For that matter, then ... IF my car was in a shop, and if economics only allow time for a "greasy inspection", I'd just instruct them to replace them all. The world has gotten WAY carried away with "numbers", "productivity", and "efficiency".
todays flatrate shops pay the same time to do todays cars, that if you haven't noticed, don't have servicable bearing.. so the "tme alloted" isn't enough time to even open it up and clean or heaven forbid, turn the rotors .. and because you have a service writers that job is more cars in per hour, you CAN'T DO IT RIGHT do it correctly, you're replaced because your not producing pull short cuts 1 out of 100 might come back.. so like try'n to fight city hall, you do the job to produce and keep your job.. why you think rotors get replaced and not turned anymore..? time.. |
um, nope, rotors are not cheaper.. when your a customer thats paying someone to do the brakes.. they pay list price+mark up.. |
Shop owners/dealerships/companies just want more more more. They don't want to pay their employees, they don't want to provide ANY benefits, but they want a specific volume of business done everyday. Too many shops today cut corners and outright CHEAT the customers. They sell work that is not necessary, and I even know about some local shops around here that remove a part, clean it, paint it black with a spray can, put it back on, and charge the customer for a new one. It's a greedy cutthroat business. It's become a thankless business. I was a professional mechanic for 25 years. I walked away from it because I can't accept what it has become. We are no longer rewarded for taking pride in our work. We are just constantly chastised because we cannot crank enough work out to meet the ridiculous goals of greedy a$$holes. A waiter in a crappy restaraunt gets a tip once in awhile from a customer. Nobody ever tips their mechanic. Engineers are designing junk, because they know they won't ever have to work on any of it. ( It's okay, the overworked underpaid mechanics can deal with it. )
crap nowadays
Expanding on 623 mantis' reply, I've noticed that cars are designed to be assembled, not repaired. I had to pull the entire sub-frame off a camry to change a clutch because some idiot didn't design an extra 2" clearance between the trans & body. My friends agree with me that engineers should be required to spend 3-5 years as mechanics first, then ,I bet, a lot of things would be better designed.
I was taught the same way.. I also pack them the old way too..By hand..
| Packing wheel bearings | Nalehed | Suspension - Brakes - Steering | 5 | 07-17-2007 10:10 AM |
| Packing for packing nut | BondoKing | Body - Exterior | 3 | 05-11-2005 09:03 PM |
| Wheel bearings | atlantis | Suspension - Brakes - Steering | 8 | 01-31-2005 06:06 AM |
| wheel bearings | stoney 81ta | Suspension - Brakes - Steering | 2 | 03-20-2004 05:56 AM |
| packing wheel bearings | chevynut | Suspension - Brakes - Steering | 12 | 01-10-2004 06:58 AM |
