Paging Kristkustoms - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2005, 01:11 PM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Paging Kristkustoms
I posted this here, instead of K/K's website because I feel the information that I will need, can be used by others when planning a hotrod interior.
I went through your website, and really liked your 19-3/4" wide buckets. When you did the 39 Chevy, how much room was left for the console? How do the seats fit a big guy? Say a 6' linebacker? How many positions do they recline, or do they just have a fold forward feature?
I'd like to continue my console up through the back seats and up to the package shelf. Reminiscent of the early vettes. How tough is it to build custom back seats to match the front? I assume it would be a plywood/foam assembly?
Or can you email me a price for
(2) bucket seats- bare w/billett handles
(1) sewing template for above
(2) rear seats to match fronts w/ a template for sewing
I'd need to know what dimensions you will want, and any other pertinanent info required. I would end up shipping the fronts separate, as I will need them for the steering column placement, and for console fabrication.
The tips you posted were fantastic. Another one highlighting interior planning would REALLY be helpful (to me)!
Thanks,
Jeff
Email: Greenblud1@aol.com
Old 02-09-2005, 03:50 PM
Interiors by Shannon's Avatar
Hey, I'm just the interior guy
Old 02-09-2005, 09:46 PM
kristkustoms's Avatar
First name...............Shawn
I generally dont post info on my products in the forums, but since it has been asked, ill answer. If another moderater thinks this should be deleted, let me know ill delete it.
But anyway, im actually fitting my seats in another 39 chevy coupe at the shop right now. Im planning a console for it, and i will have a good 8 or 9 inches of room for the console. The seat back has 20 different "clicks" when it is reclined back, so you should have no problem finding a comfortable position. For that type of person, I would recommend getting them with the 2" longer lower cushion, which I have just come out with. If you want to build your own rear seats, you can go with our contoured foam and cut it to your desired shape. Its the same profile foam thats used on my buckets, and can be ordered any width you want. You can trim it down and carve it to your desired shape.
Old 02-10-2005, 08:41 AM
Those are some sweet looking seats. I'd bet that they would even make ME look good sitting in them...
Thanks guys !!
K/K, I will email you in the near future about the seats.
Jeff
