Painless VSS? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2009, 03:43 PM
47 Coupe's Avatar
Painless VSS?
I have a Painless 60103 harness for SBC TPI speed density. does anyone know if one of the two VSS leads (1 orange and 1 black wire) is grounded? I'm trying to use an electric Autometer speedometer with the same pulse generator as the ECM uses.
Old 09-21-2009, 04:11 PM
OLNOLAN's Avatar
60103 Painless
Hey Man, I read the instruction manual for your late TPI (90-92) (60103) wiring kit. It uses the VSS signal that is a sine wave output. One wire from the VSS connects to a yellow wire from the kit harness, the other wire connects to a purple wire labeled VSS from the kit harness. Neither wire is grounded. On the early TPI kit (86-89)(60102) the VSS signal is square wave output where one wire is grounded and the other connects to a brown wire labeled VSS from the kit harness. olnolan
Old 09-21-2009, 05:44 PM
47 Coupe's Avatar
I got some info from Painless. Like it's been said the yellow and purple wires hook to the pulse generator. You have to add a wire from the ECM at BB11. This is a VSS output of 4000ppm.
Thanks for the help
Redneck-rigged VSS wiring question for 700R4 Mad Maggot Transmission - Rearend 1 02-21-2006 08:49 AM
Painless Harness and Fusible links cucumber1949 Electrical 6 10-11-2005 06:12 PM
Vss Problem NAIRB Transmission - Rearend 5 01-11-2005 08:20 AM
Need Help With Vss Problem 99 Chevy Pu NAIRB Engine 12 01-09-2005 06:33 PM
Painless wire WARNING dkasprzyk Electrical 7 08-22-2004 07:04 AM
