Painless wiring harness??How hard is it??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2010, 06:56 PM
Ok here is the deal,Im thinking of removing the LT1 engine out of the Comet and putting in a carburated 355. The previous owner installed the entire wiring harness from a 93-94 Camaro along with the engine and ECU, and the problem I have is that the wiring is a true mess under the dash....I was thinking of stripping everything out and putting in a universal Painless wiring harness to power the basics in the car, so at least I have a clue what goes to what if something goes wrong electrical. Pretty much all I need are the basics. Anyone have any experience wiring up this type of stuff? How much of a pain in the *** is it??
By basic I mean lights,horn,brakelights,fuel pump,fan,and engine.
Old 11-26-2010, 07:29 PM
302 Z28's Avatar
I doubt a universal wiring harness will be what you need, you need to buy a harness for the engine and year of the car that it came out of. I may be possible to salvage what you need from what you have so you can use the ECU, but replacing the injectors with a carb is whole nuther ballgame.
Vince
Old 11-26-2010, 07:56 PM
Vince
I said I was removing all of that. Im reffering to a chassis harness
Old 11-26-2010, 08:33 PM
life is a temporary assignment
I only use EZ-wiring... But if your pulling out the LT1.. I would buy a 21 Circuit wiring harness and pull all the other wiring out.Then install the new one.. I think that would be the easiest way to go,, Plus you will know what you have... The ones I use is just that ''EASY''... Being you want to go with the carb motor.. Get Reid of the old stuff, And start over..
I would put in a 21 circuit harness... That way if you want to add anything later, it is there..
Old 11-26-2010, 08:49 PM
EOD Guy's Avatar
I too am thinking of the painless, if I were you I'd decide on what circuits I needed....ie pwr windows/locks, etc.... and by the universal that has at least that number of fused circuits etc......
Old 11-26-2010, 09:08 PM
Trailboss71's Avatar
I have used the painless and the ez harness>the only differences I see are price and instruction manual.Wiring your car is an intimidating job but not really all that difficult.Just take your time and plan,plan,plan your routes out.my first harness took over a week, now its about 3 evenings.That's after the old junk is out.You will get a lot of peace of mind knowing its is done right
Old 11-26-2010, 09:42 PM
Are the fuse blocks labeled like "radio" "brakes" "Headlamsp", ect..So its easy to trace a blown fuse?
really all I need are bare bones, I have a 65 Pro street comet that was retro fitted with an LT1. The issue I have is I have no clue what wired to what, they put in the entire harness from the car they got the motor from.For example,right now my blinkers dont work, I have no clue where to begin diagnosing..
here is the car, look at the dash and all those guages!!!
Old 11-26-2010, 09:50 PM
Every wire is labeled about every 6'' what it is for...
Nice looking car..
Old 11-26-2010, 09:57 PM
every fuse is labled and every wire is labled like new interiors said only diff price,great looking car
Old 11-26-2010, 10:20 PM
which one is cheaper?
Old 11-26-2010, 10:21 PM
EZ-wiring..
Old 11-26-2010, 10:45 PM
sqzbox's Avatar
My pipes are my music
gauges
That is one awesome freakin' dash man. Who made that?
Old 11-26-2010, 10:52 PM
I have no clue, got the car like that.
Old 11-26-2010, 11:28 PM
Ron Francis wiring kit is awesome
I purchased a RF kit for my 47 Cad fast back 2 dr. with a blown 350 chevy. I told them what i had and they sent me a labeled fuse box and labeled wiring kit. I ran all of the wires and installed the fuses. I put gas in the car and the thing cranked right up and ran great. It was the first and last time for me and it is just a awesome set up. It been about 7 or so years and the Caddy still runs perfect. Anyone can install a this kit, each wire has the name printed on it about every 3 inches............bullet proof and easy as hell. Doing the rest of the car was taxing and hard for me but me and my two sons put the time in and made it happen. We sold the car to my brother in law so I know what is going on with it. So I suggest a RF kit and jam on buddy. Texasfats
Old 11-27-2010, 05:40 AM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
Most any universal kit could be made to work for your application. There is a long thread on this board regarding what wiring harness others have used or prefer. Some good info there along with a lot of opinions.
I used Painless to wire my T-Bucket. I would use their product again. No wiring failures of any kind in six years. Planning your wiring routes and choosing a good location for the fuse box is key. If you're using relays I like to plan those close to the fuse block as well just for convenience but it depends on what they're used for. Remember, with all these kits, you must supply the heavy gauge primary wiring from the battery to the starter / solenoid and the associated grounds back to the battery. The kit pretty much picks up from there. Each manufacturer has a web site you can go to for checking what circuits are provided in each of their products so you can pick which is best for you. Keep in mind most of these kits are designed for your typical street car so if you have anything on the car that is not typical for a driver, you may have to improvise some (I added a special circuit or two not provided in the kit and it was easy to do off of the fuse block). Having a few extra terminal strips and ring terminals on hand makes things easier as well. The one thing none of these kits address very well is taking a harness through a connector say like from the interior through the firewall to the engine compartment so you could quickly disconnect the engine harness from the system at the firewall if you pull the engine a little more frequently than most folks do.
I crimped, soldered, then shrink wrapped each electrical connection. Your instrument cluster may need additional wiring not supplied in the kit depending on what you have (couldn't tell from the picture) and whether they use electrical senders or the gauges are mechanical. I know Painless has an add-on kit for instrument harnesses but you'd want to see if it is suitable for your setup (I didn't use it and made up my own). Do you race the car? I would go with extra circuits beyond your needs for a basic kit, some day you might have nitrous or other performance goodies and having some extra circuits you can use is a plus. I made a copy of the user manual and noted in it each additional circuit or circuit that had it's usage changed from the labeled usage and it is now part of the car's documentation. Very handy later on when you make changes.
Trinary switch wiring ? fatdog Electrical 8 01-25-2010 07:57 PM
home aluminium wiring - danger pigjamelectric Off-Topic 9 07-30-2009 10:58 PM
66 mustang gauge cluster wiring harness SouthernRascal39 Electrical 2 04-14-2009 11:19 AM
Wiring Switch Box (Painless) mrdreex Electrical 6 11-05-2008 11:28 AM
Backing up 2 hard drives onto 1 external HD question ChevelleSS_LS6 Off-Topic 3 08-04-2008 11:59 AM
