Paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2010, 11:58 AM
Merlin the Magician's Avatar
Paint
I am old school as far as painting goes many coats of Lacquers and compound, compound and compound until you get the shine you want. My question is how can you tell the difference from a stage 1 paint to a base coat clear?
Old 02-14-2010, 01:03 PM
Niko1080's Avatar
A BC/CC paint job will sand white, while a single stage paint job will sand the color of the paint.
For white cars you can put the sanding dust in a glass of water, if its BC/CC the sanding dust should be clear, if its single stage white it should still show up white in the water.
Old 02-14-2010, 01:43 PM
Thanks! that is exactly what I needed to know. I just had my truck painted white and it was supposed tp be BC/CC but it just does not look right I can see a lot of swirls and body repair scratches and it does not look like it was wet sanded and buffed
Rob
Last edited by Merlin the Magician; 02-14-2010 at 01:45 PM. Reason: unsure of URL smiles
Old 02-14-2010, 02:13 PM
Niko1080's Avatar
If your not happy with your paint job and you took it to a reputable shop you should talk to them. Its their job to satisfy the customer and if you can see sand scratches from the repair, that in my opinion is never acceptable.
Old 02-14-2010, 02:18 PM
rcrobbins's Avatar
Robbins Racing
If you're seeing swirl marks it probably was sanded and buffed. Incorrect buffing by means of wool pads with the occasional screw driver spurring leaves the finish marred, swirled and holograms. This is why they've developed many stages of polishing and foam pad combinations. The only difference is the person looking at the car and how much they see; example if you're able to tell the last step of polishing from compound, polish, or burnishing. That takes skill, and I can fool most people just by compounding. It's all about how much you want to pay for, how good the person correcting the paint it is, and how blind the person inspecting the paint is. As for the single stage/bc-cc, that's answered from above. In terms of body work scratches, that's the body man and painters fault for not finishing the filler down fine enough to prevent that and the only fix is to redo, not wet sand.
Old 02-15-2010, 09:41 PM
Rag top bird's Avatar
Hot rods are still the king
This is not always true I have painted cars that dont have scratches then later shrink
paint information kimman Body - Exterior 13 06-02-2013 05:53 AM
Paint Question #157 rj57 Body - Exterior 5 10-31-2007 02:20 PM
what color to paint? jum Body - Exterior 14 07-30-2006 12:29 PM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 12:18 PM
