paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2010, 09:20 PM
docs57's Avatar
paint
hey gentlemen,problem, just painted car , stepped back noticed some blemishes, sanded to 2500, I know I have to repaint, should I sand back to 800? or will the paint stick to the 2500, help please. thank you. Doc.
Old 05-21-2010, 09:37 PM
deadbodyman's Avatar
Wiki Edits: 11
yes, resand with a coarser grit...Single stage or BC/CC?
SS 400=600
Clear 600-800
Old 05-22-2010, 03:52 AM
Rix-Trix's Avatar
Last journal entry: Box is back on the truck
IS that the 34 your just painted? What color did you go with?
Old 05-22-2010, 06:09 AM
docs57's Avatar
been painted about 1 1/2 weeks, what happened was I used the wrong paint gun, had primer in it before,not all out , little specs at about 6 places, will not sand out,must repaint , summit paint, candy apple red ss. thanks Doc
Old 05-22-2010, 10:24 AM
Man, that's a bummer. Sorry to hear that.
Or...you could put another dab of primer in the gun, shoot some more little spots in other places...and tell everybody about your custom paint job.....
Many moons ago, I painted my race Jeep with Martin-Seynour bc/cc. Used a teal main color, with red scallops. I had picked a deep red metallic for the scallops, but wanted something brighter. Working at a truck shop, I found a truck painted bright metallic red....an Imron color. I got the manager to give me a quart of that color, and shot the main part of my scallops with that. I figured that Imron was also a bc/cc paint, so it must be the same as the Martin-Seynour....wrong.
After that set up, I loaded up with the deep red to fog in around the grille, headlites and just to highlite the scallops. As I started spraying, the new paint started separating, splitting apart....like a dried-up river bed. I just figured I'd let it go and see how it dried. It layed out nice and flat, so I cleared over the scalloped area, blocked it and cleared it some more. After buffing, it was beautiful. You could see the bright red showing thru the cracks in the deep red; all my friends complimented me on the "custom" paint job. It worked out fine...just a stupid accident. And I guess I invented Vreeble by accident.....probably just how HOC did it....could happen.
Old 05-22-2010, 06:54 PM
Rix-Trix's Avatar
Thats a cool story, I do a lot of air brushing and lots of time there are little mistakes and instead of repainting it is easer to manipulated it into something cool.
Old 05-23-2010, 04:59 AM
Wiki Edits: 11
Thats the way I learned the importance of Taking the gun apart to clean it. Something will always wait until the last coat to spit out...especially on a white car....(my screw up) resand with 4-600 and reshoot the bad panels or sand the spots and blend if its a BB/CC
Old 05-23-2010, 06:47 AM
docs57's Avatar
not my car , will repaint. doc
Old 05-23-2010, 02:44 PM
Wiki Edits: 11
yeah .you cant blend that cheap SS candy paint anyway.You have to redo the whole car car.
SS is only good for solid colors....
True candies are a three stage process...
paint information kimman Body - Exterior 8 08-10-2012 08:55 PM
Paint Question #157 rj57 Body - Exterior 5 10-31-2007 02:20 PM
what color to paint? jum Body - Exterior 14 07-30-2006 12:29 PM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 12:18 PM
