paint advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2010, 11:50 AM
paint advice
Hi,
I'm new to the forum and have already had several questions answered just by reading the posts.
But, Need advice on painting a van.
I have bought the paint so I have no choice but to use it.
The paint is silver metallic acrylic enemal.
from what I read this is a hard paint to use.
I did paint it about two months but it had thin spots and orange peel
So now it is ready to paint agan.
The first time with the gun I went straight from left to right, But from what I read I think I should go straight with first pass then second time at a 90 degree can someone explain this more to me ?
thanks,
gene
Old 06-10-2010, 12:13 PM
Underground's Avatar
Last journal entry: 54
first off single stage metalic is THE HARDEST to spray and look good, ESPECIALLY for someone new to painting. The only paint that recommends a 90 difference in spraying between coats is IMRON. You just have to make sure your passes are consistent, you distance is consistent(8-10 inches depending on gun)
Old 06-10-2010, 04:04 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
Did you use a hardener in your first paint job? If not you could still have a lifting problem when you repaint. Don't try to get all your shine in one coat if your a newbe or not use to a single stage paint. Put it on med wet and work up to the shine you want. Give it plenty of time between coats when you can touch it with out it sticking to your finger your about right. As far as spray pattern on a sliver I try not to stop my spray at the same spot on all coats and some times I will change to a different angle depending how it's going on. But I can tell by flow what it needs I've maybe painted 100 or more sliver cars in my day with every thing from straight enamel to base clear.
Old 06-10-2010, 07:44 PM
Try to apply it evenly and consistently as possible, set up gun for correct spray pattern (can find in a search many places that explain setting up gun and what a proper spray pattern should look like on a test sheet), and keep gun parallel at proper distance, with a good overlap-At least 50 percent of your previous spray stroke with your next. Good wet coats so you have good gloss, but not too heavy or too low on pressure which will only contribute to mottling (not going to be able to buff out ss metallic)
If still getting a blotchy or striped look to the metallic, even though your gun is set up properly and your technique is good, then spray a panel normally, go to the next, then back to the previous shot panel and spray a mist coat right away. I like to do this by bumping up the pressure a bit, backing off the gun distance, and spraying at a diagonal -different cross angles across the panel. This should help to even out metallic. You have to get the correct timing, that you spray a panel or two, and when you go back to do your mist coat on the previous panel, it has set up just enough that when you do your mist coat-putting more material on the panel, it won't only contribute more to the mottling or striping, but done soon enough that the paint you shot on that panel is still wet enough to accept the mist coat, so it doesn't end up killing the gloss, or look dry or rough. Don't use too fast a speed reducer.
I shot some single stage metallic enamels when I was fairly new to spraying (but did have the hands on guidance of instructors the first few if needed along with a nice school booth), so its sure not undo able, but not the easiest thing to shoot, specially silvers and light blues. Basecoat sure makes metallics easier to shoot and not quite as much jumping around panels when it doesn't just lay evenly out of the gun and you have to do some more work to get it to.
Even though I've now done a bit of spraying over the years, and would know how to shoot a single stage metallic, I probably wouldn't do it any more, with how much better and easier base clear urethane is, along with having the ability to buff if wanted, and easier repairs in the future.
swvalcon is right. Enamels can have some re coat issues, sensitivity, specially if a hardener wasn't used. I'd never shoot enamel without hardener, the little extra in cost for the benefits, it would be kind of dumb not to.
Old 06-11-2010, 04:39 PM
Thanks Underground for the good advice, I repainted today
and so far it looks very good. I only painted part of the van
because I plan to two tone it.
Old 06-11-2010, 04:45 PM
Thank very much Swvalcon for your help, Yes, I did use a hardner. I repainted today and so far it looks very good. I plan to two tone the van so I only
painted part of it.
Old 06-11-2010, 04:55 PM
Thanks very much for your help, Yes, I did use a hardner.
I repainted today and so it looks very good.
Your advice and the others sure made the different.
I will try to get a picture when the job is complete.
Delamination from previous paint job. * Pics * would also like advice. Mycophiles Body - Exterior 10 03-29-2010 07:05 AM
Need advice on a paint job tishmomo Body - Exterior 36 01-15-2008 11:19 AM
Is there a place on the internet Overdriv Body - Exterior 5 09-25-2005 06:47 AM
Paint prep advice blacklabzeke Body - Exterior 1 09-21-2005 07:41 PM
paint prep advice request for toy car project pigjamelectric Hotrodders' Lounge 1 01-08-2005 06:00 PM
