paint booth heat - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2010, 08:08 PM
ogre's Avatar
the 'Duracell Project'
paint booth heat
it's cold in michigan. we keep the heat at 52 in the shop. we also have a paint booth that cools down to 50 or lower as soon as the exhaust fan is turned on. we are thinking of installing a house gas furnace to pre-heat the booth and to heat the booth after the exhaust fan is turned off. is this a good idea? the shop is 10,000 sqft, the booth is typical 12x26 ft.
any ideas?
Old 03-02-2010, 09:18 PM
paint booth heat
i put the heat banks out of two in my shop on the intake right where the fresh cold comes from attic of shop .two 10 k elements .
but wondered if i ran a water coil and heat the water would be less on the pocket , plus heat the rest of my shop .
ID:	44248   Click image for larger version
ID:	44249   Click image for larger version
Old 03-04-2010, 01:00 AM
only if you draw air for the burner flame from outside and you have to keep the manifolds clean from dust at all times ( we changed filters once a month and blew out the furnace ) , our old shop had standard force air heaters in it that drew burner air from outside the shop thru a duct , the guy who took over our shop didn't clean the manifolds or filters and decided to reroute the burner air to draw from the inside of the shop , one night one of his guys was wiping down a car for prep ( was using laquer thinner ) and had a Solvent flashback ( our worst nightmare while we were there ) and the shop exploded and burnt to the ground . this is one reason why we moved , the new shop had all the heaters mounted outside the building in a shed and ducted to the building ( drawing & heating cold air from outside ) , and the paintbooth had a electric element heater in it that was used to heat when not painting or during curing .
garage paint booth help please luckydevil Garage - Tools 43 02-27-2009 07:24 PM
Paint booth basics pols487 Body - Exterior 6 02-07-2009 07:06 AM
Need advice on a paint job tishmomo Body - Exterior 36 01-15-2008 12:19 PM
Question about new paint booth floor? FRANKBULLITT Body - Exterior 5 10-23-2007 01:03 PM
do you still heat the paint to lay it flat?? mikeweyman Body - Exterior 3 04-08-2004 12:39 AM
