Paint cans - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2013, 06:49 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Paint cans
May not be in the right category so Mods feel free to move if need be. As I have been thinking lately, I wondered why nobody makes a paint can (gallon and quart sizes) in a shape similar to the ones used for activators, that way one could pour paint, primer, and clear without making such a mess. Just a thought I had as I was cleaning the drips off the side of the can and out of the rim to get a seal.
Old 01-10-2013, 07:25 PM
496CHEVY3100's Avatar
If you remember the 60s,
Last journal entry: ,
They do,or use to it was called ditzler i still have some old can with paint still in them probably bad,now called PPG.they might still have it if ask for ,I use Dupont and , House ok Kulor now for the candy dupont for all others NO not because of Jejj Gordon
just a tip take a wedge shape peice of masking paper tape to can as a spout .drill a 1/8 hole just inside the lip of can where paint can drain back in can and not splatter when you replace the lid ,you Must use sheet plasiic between lid and can to keep from drying prematurre
Old 01-10-2013, 09:33 PM
I have put small holes in the rim of the can so it would drain, but I don't like doing that because it doesn't seem to seal back very well. I also had a few good points on another forum that if it were in the tapered top cans similar to activator it would be immortal H*** to add mixing tints and to stir would be virtually impossible. I used to have some lids for gallon cans that I bought at a hardware store that looked like someone had take the plastic spout from a 5 gallon pail and put it in a 1 gallon lid. I loved those, but haven't been able to find any for a few years. I know Lowes has a plastic version, but it is for the house paint style cans and will not fit automotive cans.....wonder if people would buy something if it were cheap enough? I may need to start a little spare time project.
Old 01-11-2013, 05:05 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
1.5" tape, that's all
The Following 3 Users Say Thank You to jcclark For This Useful Post:
carolinacustoms (01-11-2013), cyclopsblown34 (01-13-2013), John long (01-11-2013)
Old 01-11-2013, 06:55 AM
that makes an exellent spout, ive used that ,but i still get paint splatter if i dont srill small hole in rim , i use masking plastic especaly por 15 it seals good makes it easy yo remove lid ,some use sandwitch wrap ,hope this helps someone ..
Old 01-11-2013, 07:51 AM
Had an "awl" on the paint mixing bench my whole life to punch three or four holes around the edge and never had a problem with it, the can doesn't seal there, it seals round the outer edge of the lip.
Old 01-11-2013, 08:12 AM
killeratrod's Avatar
home depot has a pour cap that snap on to the top of gallon cans, it all so has a screw cap on it. They all so sell a plastic rim or lip that snaps in where jcclark puts the tape.
Old 01-11-2013, 01:30 PM
deadbodyman's Avatar
Wiki Edits: 11
If you go all the way around the can with tape it works even better...
Old 01-11-2013, 01:39 PM
Wiki Edits: 11
I tryed those snap spouts and they worked good the first time but if you dont clean them and try to use them again the new paint will lift the old paint and dried paint will get in your new paint you can strain it out but they're just too much trouble.the tape is great just throw it away when your done......
And Why is it when you drip paint down the side of a can it always, always, always, covers the part you need to read later on, the the paint code or the reduction???? .
A smart man (not me) would put tape over those spots too just in case...Hey ,Thats Spi epoxy primer, someones been listening....
Old 01-11-2013, 01:44 PM
Wiki Edits: 11
Thats what I do too..
Old 01-11-2013, 02:15 PM
I still have o e of the plastil lid covers. They do work but by the time you clean them back up, they are more trouble than they are worth. IMHO.
The timing of this thread is perfect though. This morning I just opened up my first can of SPI Epoxy. I tried the 1 1/2 inch tape trick for a spout. Man do I feel stupid. What a neet trick. It worked perfectly. I have been making messes with paint cans for 45 years and at age 68 learn how to pour paint without making a mess?
Oh well, at least I know now.
The Following User Says Thank You to John long For This Useful Post:
Old 01-11-2013, 04:58 PM
I use the paint spouts too, and reuse, and reuse...when I'm done, I wipe it off with a paper towel, then with a paper towel that's wet with lacquer thinner and it's clean...
Not to mention they make it easy to scrape the stir stick.
Old 01-11-2013, 05:35 PM
LOL, You probably remember to put your latex gloves on too. I wait until I have paint up to my elbow. I am thankull that at least now it won't be dribbled accross the work bench.
Old 01-11-2013, 06:14 PM
Real men wear nitrile I wear nitrile gloves all day in the lab. It's all I know to put them on when I work on my car, too.
I'm a nitrile glove snob too. I had to go through several brands in the stockroom at work before I found some I liked. However I will say the Harbor Freight nitrile gloves are pretty good by an extremely picky scientist's standard.
The Following User Says Thank You to Lizer For This Useful Post:
Old 01-11-2013, 06:22 PM
Real Men ? work on cars or in a lab LOL.
And this is why you ALWAYS intermix cans of paint. MARTINSR Body - Exterior 28 11-29-2012 08:05 AM
Finished marble/wrinkle paint effect using rattle cans shadowdiver307 Body - Exterior 6 10-05-2010 08:57 AM
$ 3.00 gas + vs .05 pop cans zonk Hotrodders' Lounge 12 09-09-2005 08:46 PM
Grounding Cans? Rathimis Electrical 6 01-21-2005 07:12 PM
Protection for opened paint cans willys36@aol.com Body - Exterior 6 01-13-2004 11:08 PM
