Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Paint Codes
Thread: Paint Codes
Old 04-25-2003, 02:40 PM
jwcnj45's Avatar
jwcnj45 jwcnj45 is offline
Many times the name that the manufacturer of the car uses will differ from the name the paint company will use. You are probably looking at the same color at your supplier. If you can, get the paint code from the car. Get the WA number that is printed on the lower portion of the identification label of the Corvette. I think that tag is on the drivers side door on the new Corvette. I work at a Chev. Dealer shop so I will try to get the correct info for you on Monday if I get the chance.
