Found some info thanks to my friend Mr Google.. https://autopaintproonline.com/html/...em_solver.html
--------------------------------------------------------- CRACKING Cracks or lines of various lengths and widths in the topcoat finish often resembling the cracking of dried mud. CAUSE Excessive film thickness of the undercoat and/or topcoat. Refinishing over a previously crazed/cracked surface. Insufficient flash time between coats and/or force drying undercoats using air from the spray gun. Mixing incorrectly or using too much hardener. Paint ingredients not thoroughly stirred or agitated. Breakdown of finish due to prolonged exposure to sunlight, moisture, and extreme temperature changes. Using generic reducers and/or hardeners. REPAIR Remove all cracked paint film and refinish. PREVENTION Apply all materials following label direction. Completely remove crazed/cracked finishes before refinishing. Do not force dry undercoats by fanning with spray gun air.Mix ingredients thoroughly using the recommended additives. Add each component in proper sequence following the recommended mixing ratio. Stir or agitate materials thoroughly before use to ensure all ingredients are in solution. Use premium two component undercoat and topcoat system to provide maximum gloss and durability. Use the recommended thinner/reducer and hardener, and then measure accurately ------------------------------------------------------- LIFTING The existing paint film shrivels, wrinkles or swells during new finish application or drying. CAUSE Solvents in a newly applied product attack the previous finish causing wrinkling, raising, or puckering of the paint film due to: Recoating enamels or urethanes that are not fully cured; Exceeding maximum flash or recoat times during application; Recoating a basecoat/clearcoat finish, where existing clearcoat has insufficient film build. REPAIR Remove lifted areas and refinish. PREVENTION Check questionable finishes by rubbing a small inconspicuous area with a shop towel saturated with lacquer thinner. Finishes susceptible to lifting will soften, swell or shrivel as lacquer thinner is applied. If any of these reactions occur, the following recommendations should be considered. Do not exceed a product's maximum recoat time during or after application. Allow enamels or urethanes to thoroughly cure before recoating or attempting a repair. Avoid applying undercoats or topcoats excessively wet. Avoid the use of lacquer products over an air dried enamel finish. When insoluble material (enamel/urethane) has been applied over a soluble material (lacquer): avoid sanding through and exposing areas of the soluble material. apply two component primer surfacer and/or sealer as a barrier between the new and the old finish. When applying two component undercoats over soluble finishes, the complete panel must be coated. Use water borne undercoats to repair extremely sensitive finishes. Last edited by mikeweb; 05-27-2008 at 11:38 AM. |
| The paint did not harden | powerrodsmike | Body - Exterior | 27 | 03-05-2009 05:34 PM |
| Paint Question #157 | rj57 | Body - Exterior | 5 | 10-31-2007 02:20 PM |
| "Basics of Basics" Color Matching-Alternates | MARTINSR | Body - Exterior | 2 | 02-03-2007 06:33 PM |
| This is interesting. Temporary peel off paint. | kenseth17 | Body - Exterior | 5 | 08-11-2005 09:41 PM |
| Can I put clearcoat on top of a lacquer paint | viperACR | Body - Exterior | 10 | 06-18-2004 10:44 AM |
