Paint Cure Time - How Long Should You Wait - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2006, 10:32 PM
bigbrowndog's Avatar
Last journal entry: Found some headlamps
We are painting my son's car. He will be anxious to drive it. How long should we wait? Doing our first base coat/clear coat project.
Thx
Ty
Old 04-14-2006, 04:54 AM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
Let it set in the sun for a couple of days when you are done.. it will be fine.. you dont even have to do that, it will just aid in curing it
Old 04-14-2006, 04:55 AM
adtkart@aol.com
How long you should waut depends on several things. The materials you are using will be one determining factor. The temperature and humidity will effect the cure time. Also what kind of driver is he, and how much work have you put into the project? If he has a bad driving record as far as hitting things, obviously you need more time for it to cure. LOL
Aaron
Old 04-14-2006, 08:36 AM
302 Z28's Avatar
Two schools of thought on this issue.
One says color sand within a day.
Other says wait several weeks to color sand.
Later method says that if you color sand early and buff after several weeks the surface will not look as smooth. The theory is the clear is still settling within that first few weeks and if you wait to color sand you will get a much smoother surface that will hold it's smoothness.
Best method IMO is to color sand several weeks after the final clear. Color sand the entire vehicle and place it in the sun for several hours before you buff.
Vince
"Basic of Basics" What kind of paint should I use? Centerline Body - Exterior 5 10-21-2007 11:32 PM
long time reader, 1st time user brandon624 Introduce Yourself 1 03-13-2006 04:16 AM
A long long time ago, in a galaxy far far away.... WakBordr7387 Hotrodders' Lounge 2 05-19-2005 03:07 PM
Hey Guys Long time no talk too !!!!! chevyluvnpuppy Hotrodders' Lounge 29 10-19-2004 06:36 PM
paint or wait... gt2betubbed Body - Exterior 3 09-04-2003 05:08 AM
