paint eating paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2005, 09:24 PM
paint eating paint
allright heres a good question that I've been wondering about. why does some spray paint eat other spray paint? i was rattle-canning my racecar tonight
and the paint I used for the racing stripes, ate the paint that i laied down weeks ago. witch is rattle can to, the same brand..... whats up with that?
Old 11-14-2005, 03:58 AM
milo's Avatar
point on positive
Are they also the same kind as well as brand?
For instance if you put lacquer on top of enamel you'll have a lifting problem however you can put enamel on top of lacquer with a better chance of success.
need more information of exactly what your spraying on what.
Old 11-14-2005, 11:34 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
WHAT kind would help.
I'll assume it's enamel. Which takes a LOOOOOOOG time to fully cure so IF you paint over it,even a week or more later,the SOLVENT in the fresh paint will wrinkle the underlying paint. Same issue with repairs or cut thru's.SOLVENT from the new work's into a gap or edge and starts reacting with the old.
Lacquer DRY'S fast and has a "somewhat" protective top layer.So the Enamel SOLVENT can't get into the paint.Course, you CAN apply too much enamel and it WILL work it's way into most any paint.Not very often but it can happen.
Old 11-16-2005, 10:40 AM
its cheap spray enamel from wall mart, yea, that color place cheap stuff
"Basic of Basics" Can I use "rattle can" paint on my car? Centerline Body - Exterior 33 07-08-2011 12:33 PM
Need advice on a paint job tishmomo Body - Exterior 36 01-15-2008 11:19 AM
Sherman Williams Clear Coat Failing < 3 Years? DeJarnett Body - Exterior 33 12-11-2005 10:39 AM
Painting roof tips needed..... Bluepen Body - Exterior 7 09-10-2005 09:26 PM
This is interesting. Temporary peel off paint. kenseth17 Body - Exterior 5 08-11-2005 09:41 PM
