Paint flattener - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2003, 07:07 PM
Post Paint flattener
I shot some Centari paint in my engine compartment, I tried it with flattener addative on an old door, all it did was thin the paint and make it run. What did I do wrong? What does activater do for paint?
[ May 02, 2003: Message edited by: Gassman ]</p>
Old 05-02-2003, 07:23 PM
mitmaks's Avatar
Last journal entry: Grille
Post
i dont know how you "shot" it but it wasnt supposed to run on you at all, u probably did something wrong, a flattener makes your paint/clear coat look less glossy, "deglosser"
Old 05-06-2003, 12:47 PM
Dragon J's Avatar
Last journal entry: Harley/Fire
Post
Be sure to read all tech sheets before you mix chemicals. Flattener as stated will 'degloss' and make the paint dull, activator is usually used in basecoat to make the paint 'active' and cure. It sounds like the paint was thinned too much with reducer or thinner or you mixed too much of one as opposed to the other... again be sure to read all labels and tech sheets.
