Life is too short!!!
If you dont have the means to protect yourself stop doing it or get someone else to do it. I had to buy the 3M self contained fresh air system that all fits on a belt. I wore that friggin thing 9hrs a day for almost 3yrs. I now have to wear that stupid thing when I mow the yard when i clean my bathroom. My health has gotten worse over the past few years because I was too friggin stupid to leave the collision repair field behind. I recently walked away this march and only wish I had done it years ago. Your lungs will NEVER get better and trust me you dont want to be put on the lung transplant list. Ill have someone smother me with a pillow before I go down that road. Ill be 30 in September and told by a few specialists that I might make it til am 40. Life is too short for a stupid car!!! |
Since 68, Sometime in the early 70s I became aware of the hazards and began to take extra precaution with ventilation, respirators, etc. The hazards depend a great deal on what you are welding on but all of it can lead to serious problems if steps are not taken to prevent fume exposure. Welding can lead to several problems besides breathing such as nerve damage and heavy metals poisoning that can affect a person in various ways. Like most everything else it will depend on the amount, type and length of exposure plus a person's tolerance but if he choses this as a lifelong profession he needs to be aware that his health can suffer if he is careless. In this hobby welding on cars can expose someone to some very dangerous welding fume that can cause serious problems even in the short term, some of these problems can even be life threatening. Welding on cars with older lead containing paint can be dangerous and welding on Zinc and Cadmium plated parts can cause problems in short order! Those fuel lines are one example of a potentially dangerous item to weld on as is some exhaust pipes and anything galvanized should be treated as potentially deadly which it most certainly is!
If your son is passonite about welding then the best thing to do is gain knowledge about the risks.
If you know what you are up against then you can protect yourself. Hornell/speedglas makes a great fresh air unit built for welding, very nice unit cost around 1200. 1200 might sound like alot but its not when you stop and think it...Eric |
He's Not passionate about it, but has been told by his supervisor at the shop he works at that he is a natural born welder. He want's to be a Rock+Roll Star
I have been the one that has been pushing him to get a "Real Job" Maybe I should mind my own business
There cannot be two worse health hazards to a person then welding and painting - and I do both occasionally. Last week I did some epoxy and 2K priming - OUTSIDE - and dam' the dust as it will be sanded anyhow. Evidently my mask (new with new cartriges) had a poor fit (no facial hair) as I had trouble even talking the next day along with a "hangover" kind of headache. I have a supplied air respirator and thought painting out doors would not cause me a problem as that set up is a PITA to use. Regardless, it's getting fired up today for some more priming fun - no more sore throats and "solvent hangovers" with potential long term and permanent lung and brain(
) damageDave |
Those little test capsules are real handy for fit testing and will let you know if there is fit problem or not. Quite often there will be a tiny leak that a person can't detect by smell and even this is enough to cause a problem as you have found. Sometimes if a person is accustomed to a smell, as painters often are, they may not be able to detect a dangerous odor from a leak that someone who has not been around it much can smell quite strongly. Just pop one of those things and hold it close to the mask and if there is a leak it will be apparent, if you don't have any I have discovered that burning a small piece of most plastics will produce an acrid smoke that makes a leak quite detectable. Don't burn much plastic inside a building because some of it produces a smoke that is really toxic, a tiny piece will usually be enough.
The mask also has to seal with only "natural pressure" on it. Placing your hands on the intakes will provide additional pressure on the mask, helping it seal. It may not be much pressure, but unless you are going to spray while pushing on the mask, it won't tell you how it is working while spraying.
Aaron |
The part about placing your hands over the air intake holes was on my first North respirator's instruction sheet but it did include the little odor capsules as well. The new one didn't include the capsules so I just use a few drops of regular lacquer thinner on a rag instead
. What I don't like about my new North respirator is the behind the head strap that doesn't hold it tight and evenly without cutting off my brain blood supply so I find that I'm reverting to my old and crusty one.Might have to research another brand plus use my supplied air system more religiously on the nastier stuff, tho a PITA Dave |
[QUOTE=Irelands child]The part about placing your hands over the air intake holes was on my first North respirator's instruction sheet
The new one didn't include the capsules so I just use a few drops of regular lacquer thinner on a rag instead That recommendation was, and maybe still is, included with some respirators and was for a long time the accepted method for checking fit but because of the problems mentioned it has fallen out of favor. In those demonstrations at the safety training sessions it was really surprising just how faulty the method is and just how often it failed. As Adtkart pointed out even the small amount of pressure from placing your hands on the filters tight enough to seal them is enough to cause a false test result. Also using something like Lacquer thinner can give a false sense of safety since odors we are accustomed to (most painters can't smell Lacquer thinner if they stick their nose in the can ) usually are hard to detect by someone around them regularly. For example my wife and daughter along with some visitors will gag from the strong smell of my parts cleaning tank when they get anywhere near the garage but For me and my buddies who are around it all the time we can hardly smell the stuff at all.
| Paint Question #157 | rj57 | Body - Exterior | 5 | 10-31-2007 02:20 PM |
| Best Way To Mask Paint Fumes | ISAAC-RAY | Body - Exterior | 22 | 09-25-2006 11:29 AM |
| wax and grease remover | adrock430 | Body - Exterior | 14 | 07-30-2006 12:18 PM |
| paint fumes | Pidek1 | Body - Exterior | 2 | 06-12-2004 04:00 PM |
