Paint Fumes - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 07-04-2007, 09:37 AM
Irelands child's Avatar
[QUOTE=oldred anywhere near the garage but For me and my buddies who are around it all the time we can hardly smell the stuff at all. [/QUOTE]
I probably should have pointed out that lacquer thinner odor to me is very noticeable - and is not really a good test for those that paint on a daily basis. I paint so seldom that it works for me.
Sorry if my brain and my two typing fingers and 1 thumb don't always communicate as well as they should for others
Dave
Irelands child
  #32 (permalink)
Old 07-04-2007, 01:32 PM
Just a note. I was looking at the plastic bag I keep my mask in. It states, to check for proper fit, to do a negative pressure test , like I suggested, and a positive test. I don't think any more would be necessary. If you think about it, after whatever test you use, five minutes or whatever later, you yawn or stretch, swallow, sneeze, your mask is going to move if it is not properly fitted and even then it still is not likely going to be 100%
  #33 (permalink)
Old 07-04-2007, 02:01 PM
As I said that was the accepted method for a long time however those comparison tests we did were real "eye openers" and it was really surprising just how much of a leak that was quite apparent with the test caps would seal off and not be noticeable at all when doing the negative pressure test. Try this, make sure you do have a small leak around the mask and then lightly place your hands over the filters in such a manner as to block as much air flow as possible then inhale in a normal manner-Most leaks will seal due to the pressure differential and not leak at all when this is done however when the filter restriction is removed the leak will still be there. some really serious leaks can be overlooked in this manner.
  #34 (permalink)
Old 07-04-2007, 02:32 PM
Who besides North and 3M make 1/2 face masks that have a good harness system? While I have used the North masks with good results in the past, last week's debacle with talking and a solvent 'hangover' was an eye opener for me and that a new manufacturer might be in order for those days I don't use my fresh air system (no lectures - I know I should use it, but it isn't always convenient if I have only a single panel to spray)
Dave
Irelands child
  #35 (permalink)
Old 07-04-2007, 02:40 PM
3M makes several different models and the much softer black Silicone model (I forget the number, must have had too many leaks ) will seal a heck of a lot easier than the stiffer two-tone grey ones (can't think of the numbers on them either ). I started using the Silicone masks a long time ago and I never have much problem getting a good seal anymore.
  #36 (permalink)
Old 07-04-2007, 02:48 PM
wildman1932's Avatar
Dave's hot Rod Shop
Fresh air supplied, with positive pressure is the best.
Vapor cartridge is next, if you have no facial hair, if you do, it is probally leaking. They won't even test you!!!! The new rule is, if you have facial hair, you can not be tested.
Dave Tallant
  #37 (permalink)
Old 07-04-2007, 03:01 PM
Dave
I have been using Advantage 200 LS made by MSA { Mine Safety Appliance Company } I like it
  #38 (permalink)
Old 07-04-2007, 03:06 PM
My old and new Norths are silicone masks but for some reason I can't seem to get a good seal with the new one - and I don't have any facial hair except when I don't shave for a day. I have even toyed with the idea of using Vaseline but what a mess it would create .
I had a brain wave and took a quick "tour" of my MSC catalog - and there are many choices from way too expensive to way too cheap to consider but am going to try the North one more time then make a decision.
Dave
Irelands child
  #39 (permalink)
Old 07-04-2007, 03:18 PM
Dave
Did you get the right size ??? I know sometimes when I am in a hurry I have just grabbed something, later to find out @##$%
  #40 (permalink)
Old 07-04-2007, 03:59 PM
Yep - a large but have done the same @@%$$## as well
Irelands child
  #41 (permalink)
Old 07-04-2007, 04:15 PM
Using Vasoline is not only a good idea but has been done a lot, but as you said it is messy. When I ran my welding shop we sometimes had to cut/weld on Galvanized tanks or other Galvanized metal and when this was done it was extremely important not to have ANY leaks. In places where it was not practical to use a fresh-air unit we used both full face and half face masks, depending, and Vasoline was used as added insurance. It has been for me anyway that the full face masks are harder to seal than the half face type (others may have had a different experience with these things) and the vasoline made it much easier to achieve a good seal.
  #42 (permalink)
Old 07-06-2007, 12:51 AM
You were saying that you have been welding as a profession for 30+++ years. I was wondering, How is your health ??? Like I was saying, my 20 year old son is heading down that road. Just wondering if you had to do it over, Would you do it again ??? Jack
  #43 (permalink)
Old 07-06-2007, 03:07 AM
I have a few things here if anybodys interested.
http://www.1969supersport.com/respirators.html
Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
Rob
  #44 (permalink)
Old 07-06-2007, 06:36 AM
Rob
Rob,
Thanks for the reminder post - I've seen your concerns and advice on previous posts and again re-read them.
I do have one comment - we were issued a Scott 1/2 face respirator at one power plant we were building. It might be a life saver, but it did not fit with a good seal even after professional set up and for sure can not be used for car painting. I trashed mine once I moved to the next project since they had a different and better mask/hood system,
Dave
Irelands child
  #45 (permalink)
Old 07-06-2007, 06:56 AM
On the original topic, I have a couple of suggestions... Given that there are risks that you're aware of and you're considering painting anyway:
1) About 10 years ago when I was taking body shop classes at a community college as a means of working on my cars (which, by the way, might be a way for you to access a down draft paint booth) some of the latest in paint technology that was being discussed was water-based automotive paint. I don't remember much more than that, but an internet search seems to point towards "Auto Air Colors" as a company that is making this kind of paint.
2) Not too long ago there was a discussion on here about Rustoleum applied by roller. The technique involved a lot of sanding, but maybe it's easier - particularly with wet sanding - to protect against dust particles than vapors.
Paint Question #157 rj57 Body - Exterior 5 10-31-2007 02:20 PM
Best Way To Mask Paint Fumes ISAAC-RAY Body - Exterior 22 09-25-2006 11:29 AM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 12:18 PM
paint fumes Pidek1 Body - Exterior 2 06-12-2004 04:00 PM
